I am trying to control a servo motor using PIC 12F675. I was successful in driving the servo as well as achieving the speed control for the servo. Thanks for the help from Stack Exchange
Now, my speed control is quite flaky. I tried tweaking my code here and there but I have had no success so far.
My main objective is that the servo should spin 0 to 90 and back based on the data from toggle switch. I achieved this goal. When I turn a potentiometer, the speed at which the servo rotates should change. I achieved this too. However, the servo is not rotating 90 degrees at all the time.
It rotates 90 ish -120 degrees at high speeds and rotates only 30-45 degrees on low speeds (or some weird behavior is happening). I want my servo to rotate 90 degrees but just my speed should vary.
Can any one point me to the error in my code?
GO_DONE=1; // start ADC
while(GO_DONE); // wait for ADC to complete
V_in=(ADRESH<<8)|ADRESL; //copy ADC values into a variable V_in
quotient=V_in/200; // I am dividing this because I will have integers between 1 to 5
// I am using this quotient value to magnify/diminish my time delays for speed
if(quotient<=1)
quotient=1; //fool proofing
if(GPIO&(1<<3)) //checking whether toggle switch is high. If yes, go forward else reverse
while(counter>1000) //this counter is for the delay cycles.
counter=counter-(20*quotient);
GPIO|=(1<<2);
cnt_1=counter;
while(cnt_1>0)
__delay_us(1);
cnt_1--;
GPIO&=~(1<<2); //low signal
__delay_ms(18);
cnt=1000;//reset of counter for reverse direction
elseif(!(GPIO&(1<<3))) // check if switch is low
while(cnt<1500)
cnt=cnt+(20*quotient);
GPIO|=(1<<2);
cnt_2=cnt;
while(cnt_2>0)
__delay_us(1);
cnt_2--;
GPIO&=~(1<<2);
__delay_ms(18);
counter=1500;//reset of counter for forward direction
