Any time you connect different circuits they will have interactive effects because the sub-circuits are elements themselves and form a higher level circuit with these more complex elements that have more complex analogous laws to ohms law, etc.
This is not a bad thing but makes analyzing such circuits complex and their behavior even more complex.
The general method of keeping sub circuits from interacting in the complex ways(which makes reasoning about them difficult) is to isolate them.
If we are dealing with voltage characteristics(e.g., thinking about how the voltages of one thing behave and feed in to another) and don't care about the current, then by making the input of one circuit to have very high resistance will prevent it from loading the output of a circuit connected to it.
e.g., imagine this as a simple model for a more complex circuit:
R2 has such a large "input" resistance that the output of R1 is effectively the same as if R2 was gone(after all, if resistor is missing we could actually just say it exists and has infinite resistance, and so there are a infinite number of infinitely large resistors in that diagram that I ignored to save time ;).
Now, R2 is just a resistor, With op amps, they too need large input resistances to avoid loading, but that doesn't mean no signal gets through, remember, they are active and have power to do things a resistor can't.
So, you have to make sure you input resistance(just trace the paths and add up the resistance) is large. remember than the input resistance for a standard op amp can be though of as infinite so you can basically ignore the op amp's inputs(disconnect them) for this purpose.
now, suppose you do this, as you have done, and noticed that you have a low input resistance. What do you do?
- You increase the components values to give a higher resistance but the same output. Remember, you can do this because generally the "values" of an opamp circuit, by design, depends on the ratios, not on the absolute values.
Hence you could have 1ohm/1ohm or 1Mohm/1Mohm. The first has a low input resistance and the second a high but both give the same op amp output(think of something like a standard amplifier). There are limits of course. You can't do it too much because of other problems(noise, interference, etc).
So, what can we do better?
- We use a buffer. A Buffer is like a resistor but it is much better. It is an op amp or other device that has unity gain, has high input resistance(use use very large resistors like 10Mohm/10Mohm) and very low output resistance(because that is what op amps do, high input and low output resistances and that is what makes them so valuable).
Jfets, BJT's, mosfets all have similar characteristics but an op amp is a "super transistor" and does a better job.
So, either increase your R2 and C2 in such a way as to retain the same response but increase the input resistance or insert a buffer in between the two to isolate them. E.g., if you can't change C2 or R2 because you don't have a large enough cap or it will make the response go outside the limits you want, insert another op amp in between and choose to large resistors instead. It's a trade off, of course.
Sometimes there are other topologies that can mitigate the issues in a different way. EE is part art and part science. You have to play around with things sometimes and also make compromises sometimes. You generally have a operating range of voltages and currents you can work with and components and $$$. It's your job as an EE to find the best overall values.
out
voltages now have magnitudes that do not reflect the expected values (they're much higher approaching vcc+) \$\endgroup\$
