I have the Freetronics Eleven, which is 100% compatible with Arduino Uno. Ultimately, I want to make a foot pedal switch that connects to a digital pin on the arduino so that a LOW is read when the pedal is pressed, and a HIGH is read when the pedal is released, or vice versa.
At the moment I'm just trying to test making a switch of the same behavior by sticking wires in the pins and connecting them together. I've tried connecting and disconnecting pin 2 and gnd, pin 2 and 5v, pin 2 and pin 12 etc. with pin 2 set to input.
What is the correct setup to make a basic switch? Which pin do I connect to which to make it so when the pins are connected one reads low instead of high, or vice versa?
EDIT: Thanks for telling me about the pull-up resistor. I have since discovered via google that the arduino pins have built-in pull-up resistors. For others who come along this problem, this is how you enable them:
pinMode(10, INPUT); // set pin 10 for input
digitalWrite(10, HIGH); // set pull-up resistor on pin 10
then to use:
if (digitalRead(10) == LOW) // pin 10 is connected to gnd
    doSomething();
else // pin 10 is not connected to gnd
    doSomethingElse();
  • \$\begingroup\$ I would say that a switch for Arduino is not different from a switch for anything else. \$\endgroup\$
    – clabacchio
    Feb 16, 2012 at 10:21
  • \$\begingroup\$ arduino.cc/en/Tutorial/Switch ladyada.net/learn/arduino/lesson5.html \$\endgroup\$ Feb 16, 2012 at 11:08
    \$\begingroup\$ The internal pull-ups are very weak. There is a good deal more that probably ought to be done, especially if you're connecting this footswitch on a long wire. A capacitor to slow the transition a bit, an inline resistor or buffer to protect the Arduino, and debouncing the switch in software are all things you should look into. \$\endgroup\$ Feb 16, 2012 at 14:19
What you need is a pull-up resistor.
The Arduino whebsite has a nice tutorial (with software) on using a pushbutton.
We connect three wires to the Arduino board. The first goes from one leg of the pushbutton through a pull-up resistor (here 2.2 KOhms) to the 5 volt supply. The second goes from the corresponding leg of the pushbutton to ground. The third connects to a digital i/o pin (here pin 7) which reads the button's state.
  • \$\begingroup\$ Beat me to the punch, I was typing an answer as yours popped up :) @Nicholas Grasevski, Another way to visualize this with a schematic. 2k2Ohm is a little stiff but will work just fine .I usually prefer 4k7-10kOhm depending on what I have on hand. \$\endgroup\$ Feb 16, 2012 at 4:35
