Referring to the MFRC522 RFID Reader/Writer rfid reader writer module. How do I configure its UART so it can talk to an rs232 port of a PC?
The answer is probably similar to this question
https://arduino.stackexchange.com/questions/30719/how-to-program-an-nrfl01-rf-module-that-is-connected-to-a-pc-via-a-usb-to-uart-t
which point out that it not easy to write PC software (not suprisingly) for a arduino module with same interface. So the question is then -is there an existing PC software for this?
There's an existing Arduino library that uses the module's UART interface, rather than the more common SPI. It provides basic methods for reading the UID of a card and R/W operations on blocks. You could easily port that library to your favourite PC programming language, connect the module to your PC probably through some USB-UART adapter and get to work.
If your PC has an actual TIA-232 serial port and you want to use that to talk to the module, you'll need a driver like the MAX232 to sit between the module's TTL UART and the PC serial port.
Use this as a guide:
All GNDs must be connected together.
  • \$\begingroup\$ I am new to hardware and would like a circuit diagram. What are the circuit diagrams for the rs232 answer you mention? And yes, my desktop PC does have an RS232 port on it. \$\endgroup\$ Commented Nov 1, 2016 at 9:13
  • \$\begingroup\$ Do you need four pins rather than three for rs232 connection for this module? \$\endgroup\$ Commented Nov 1, 2016 at 10:45
  • \$\begingroup\$ Four or three pins?-what the exact circuit to interface to rs232?-I dont think the answer is that easy too \$\endgroup\$ Commented Nov 2, 2016 at 11:55
  • \$\begingroup\$ @yabbadabba You only need 3 pins for UART. See my edit. \$\endgroup\$ Commented Nov 2, 2016 at 12:09
  • \$\begingroup\$ I get the general idea of you guide solution and why an max232 maybe needed. But maybe I misunderstood something -I thought UART was not the same as RS232 -so it doesnt make sense to me to say it needs 3 pins. I thought maybe the DTR line maybe needed. \$\endgroup\$ Commented Nov 2, 2016 at 15:14
