I am trying to connect my HC-05 bluetooth module with PIC16F877A. I know we have to use USART to talk with bluetooth module. So I started with USART of PIC by reading its datasheet.
I am using MPLABX IDE with XC8 compiler and i am not interested in using any libraries.
// CONFIG
#pragma config FOSC = HS       // Oscillator Selection bits (HS oscillator)
#pragma config WDTE = OFF       // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = ON       // Power-up Timer Enable bit (PWRT enabled)
#pragma config BOREN = ON       // Brown-out Reset Enable bit (BOR enabled)
#pragma config LVP = OFF        // Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit (RB3 is digital I/O, HV on MCLR must be used for programming)
#pragma config CPD = OFF        // Data EEPROM Memory Code Protection bit (Data EEPROM code protection off)
#pragma config WRT = OFF        // Flash Program Memory Write Enable bits (Write protection off; all program memory may be written to by EECON control)
#pragma config CP = OFF         // Flash Program Memory Code Protection bit (Code protection off)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#define _XTAL_FREQ 20000000
#include<xc.h>
void main(void)
unsigned int i;
TRISA=0xff;
//UART
TRISC=0X00;
TXSTA=0X20; // TX RS232 settings
RCSTA=0X80; // RX RS232 Settings
SPBRG=31; // Baud rate is set based on Crystal clock
TXSTAbits.TXEN=1; // Enable RS232 transmission
RCSTAbits.SPEN=1; // Enable RS232 reception
while(1)
TXREG= 65;
__delay_ms(200);
I used the above code to send a char 'A' from PIC to USART and was successful in reading it using my serial monitor on PC (with RS232).
Now form what I understood, if I replace the RS232 with my bluetooth module I should get the same char 'A' transmitted to my mobile phone.
I am using Bluetooth Terminal android app to check the reception of data. But the after the app connects to the module it just shows a blank screen. I dont receive anything.
What could be the reason please help me!!!!!!.
Things that I tried :
  1. There is no problem with the baud-rate, both my Rs232 and HC-05 works at 9600. I have ensured the same using my arduino and HC-05.
  2. there is no logic level problem I have used a potential divider to shift 5V to 3.3V.
I am quite new here so forgive me if my question is not that appropriate.
Hi guys I finally made a full working program for interfacing PIC with HC-05. The complete details can be found here: https://circuitdigest.com/microcontroller-projects/bluetooth-interfacing-with-pic-microcontroller
    \$\begingroup\$ It's better to include code into your answer instead of referring to some external page. And include explanation what fixed your problem. \$\endgroup\$ Jul 26, 2017 at 4:47
  • \$\begingroup\$ Why is that? Why should I create a duplicate when I have already posted the details there? NO OFFENCE!! Just curious to know. \$\endgroup\$ Jul 27, 2017 at 5:04
  • \$\begingroup\$ electronics.stackexchange.com/help/how-to-answer \$\endgroup\$ Jul 27, 2017 at 7:10
  • \$\begingroup\$ Good answer = you explain solution to the problem in this answer. Bad answer = link to another site where is the answer. \$\endgroup\$ Jul 27, 2017 at 7:14
