7
My design uses an IC with bi-directional I/O pins. For various reasons I need to connect GND to one of these pins, but Kicad warns about this:
ErrType(4): Conflict problems between pins. Severity: warning * Pin 1 (Power output) of component #FLG032 is connected to * Pin 4 (Bidirectional) of component U1
I can override this warning globally in the ERC settings, but is there a better way to disable the warning for just this one pin?
  • \$\begingroup\$ Personally, I just note the issue, and once verified correct, ignore it in the ERC log. \$\endgroup\$
    – rdtsc
    Commented Nov 4, 2016 at 20:33
If you know that your I/O pin won't be outputting (that is why the warning is defaulted for I/O), then you can use a Net Tie:
Net-Tie
The Footprint looks like this:
Net Tie footprint
