Im trying to store some data in the 24AA01 EEPROM using the PIC18F13K22. Since I am awaiting the components, I thought I will go ahead and simulate it in Proteus.
Schematic
This is my code (XC8 compiler based).
#include <xc.h>
#include "config.h"
#include "uart.h"
void i2c_writebyte(char x);
char i2c_readbyte();
void main(void) {
    OSCCON = 0x43;  //2Mhz
    TRISBbits.RB4 = 1;
    TRISBbits.RB6 = 1;
    TRISCbits.RC5 = 0;
    LATCbits.LATC5 = 0;   //Low to Enable Writing
    SSPADD = 4; //100kHz
    SSPSTAT = 0x80;
    SSPCON1 = 0x28;
    char a = 'y', c;
    uart_init();
    i2c_writebyte(a);
    c = i2c_readbyte();
    print(c, 1);
    LATCbits.LATC5 = 1;   //High to disable Writing
    while(1);
    return;
void i2c_writebyte(char x){
    try:
    SSPCON2bits.SEN = 1;    //Start bit
    while(SSPCON2bits.SEN != 0);
    SSPBUF = 0xA0;
    while(SSPSTATbits.BF != 0);
    while((SSPCON2 & 0x1F) || (SSPSTAT & 0x04));
    if (SSPCON2bits.ACKSTAT !=0){
    print("1", 1);
    return;
SSPBUF = 0x0;   //Address
    print("2", 1);
    return;
SSPBUF = x;   //Byte
    print("3", 1);
    return;
SSPCON2bits.PEN = 1;    //Stop bit
while(SSPCON2bits.PEN != 0);
char i2c_readbyte(){
    char x;
    try:
    SSPBUF = 0xA0;
    print("4", 1);
    return;
    print("5", 1);
    return;
    SSPBUF = 0xA1;
    print("6", 1);
    return;
    SSPCON2bits.ACKDT = 1;
    SSPCON2bits.RCEN = 1;
    while(SSPSTATbits.BF == 0);
    x = SSPBUF;
    SSPCON2bits.ACKEN = 1;
    return x;
I use the UART to tell me at what point the ACK was not received. The oscilloscope also confirms that when I check the waveform.
Waveform
Why isn't the EEPROM providing an ACK? Is it a simulation bug or am I doing something wrong?
Changing the pull-ups to 10k and 4.7k had no effect as well. I used an I2C debugger to see if the correct data was going but I saw something like this. Can anyone help me intepret this?
I2c Debugger
  • \$\begingroup\$ I don't have time to review your code, but I notice that your I2C pull-up resistors are very low value (i.e. "strong") with a value of 1k. Please change both those resistors in the simulation to 4k7 or 10k, re-test, and update the question at the bottom with the result of that test, so all readers can see that result easily. \$\endgroup\$ – SamGibson Nov 2 '16 at 15:23
  • \$\begingroup\$ It created no change. \$\endgroup\$ – hp07 Nov 2 '16 at 15:26
  • \$\begingroup\$ @Sam a 100k worked for some reason \$\endgroup\$ – hp07 Nov 4 '16 at 14:50
  • \$\begingroup\$ "100k worked for some reason" - As Scott also mentioned in a comment on your answer, in real life, that is not a sensible value for I2C pull-ups. This suggests that there is a problem somewhere in the simulation you were using. \$\endgroup\$ – SamGibson Nov 4 '16 at 16:28
  • \$\begingroup\$ FYI - Although I have not used Proteus for a long time, I found this previous EE.SE question "I2C pullup resistors not working in simulation" which suggests that I2C pull-up resistors cannot necessarily be simulated as normal resistors in Proteus. \$\endgroup\$ – SamGibson Nov 5 '16 at 0:29
Solved ... to anybody who has this problem - change the pull ups to 100k and it works like a charm.
I request the Op to archive this question so that the code can be used by others who might need it.
    \$\begingroup\$ 100k is simply a whacky number for an I2C pullup. \$\endgroup\$ – Scott Seidman Nov 4 '16 at 15:05
  • \$\begingroup\$ I know, thats why i didnt try it in the beginning \$\endgroup\$ – hp07 Nov 4 '16 at 22:08
