I am going to design a fairly simple binary LED wrist watch. For a cool feature and a good learning experience I want it to have wireless charging capabilities so I purchased this wireless charging set from adafruit link
Unfortunately this set comes with no documentation and I can't even find who made it. I'm pretty new to wireless charging so I'm wondering what sort of shielding will I need to protect the other electronics on my board? I am thinking I'll put the coil on the bottom of the PCB and everything else on top. Will something as simple as a layer of aluminum foil do the trick?
I've done some research but everything I've read so far is pretty complex (and $$) for what I'd like to do for such a simple project.
  • \$\begingroup\$ 1st lesson in EE, don't buy anything with crappy or non-existant documentation. So how are you going to fit that coil in your (presumably expanding) wristwatch? \$\endgroup\$
    Nov 3 '16 at 17:52
  • \$\begingroup\$ Its actually not that big. About the size of an apple watch. For $10 this couldn't be passed up! \$\endgroup\$
    – Mtk59
    Nov 3 '16 at 18:23
  • \$\begingroup\$ I would put some foil between the coils and see how much it lowers the power transfer. If foil isn't looking promising (mild attenuation would be 1/8th of the power) I would try a ferrite shield. I have adhesive flexible ferrite sheet lying around for when I need to tinker with EMC compliance issues. \$\endgroup\$
    – Matthew
    Nov 3 '16 at 22:14
