We have a product that is a toy bug net. At the bottom of the bug net is a coil that reads bugs with RFID tags in them.
For most of the bugs this seems to work fine and the net is able to identify the bugs. But for certain bugs, the way that the bug lands in the net seems to affect whether the bug gets read correctly.
I guess this makes sense because the passive RFID tags need to be aligned a certain way in order for it to get energized by the coil's magnetic field. Is there something that we can do, short of repositioning or remodelling the bugs so that they won't land in the 'bad' orientation?
RFID coils usually line in a single plane - ie they are essentially 2D on shape but will hav 3D thickness.
The coil at the bottom of the net could be wound in 3 dimensions rather than 2 to allow it to be less "null sensitive".
Or two windings could be used that are either processed separately or combined in some analog manner.
An extremely good guide to RFID aerial design is given in
Microchip application note AN710 Antenna Circuit Design for RFID Applications
  • (Maintenance page here )
Also liable to be of significant assistance is
Microchip AN680 microID® 13.56 MHz RFID System Design Guide
Two "loop" aerials which are essentially 2D in shape will have a very distinct null when aligned orthogonally (ie at right angles). If the fixed antenna is on a flexible substrate then simply bending it in a curve will reduce the tendency to form sharp nulls, but will also reduce the peak response when the aerials are optimally aligned. In this application optimal alignment is unlikely to be important.
For $ IEEE paper RFID high frequency 3-dimensional loop antenna analysis and design
  • ABSTRACT: This paper presents an analytical model for a single folded loop antenna with detection coverage in three dimensions of space. Based on the antenna theory, the inductance and impedance of the loop antenna is investigated. The electromagnetic simulation is used to determine proper antenna topology for optimal performance. The proposed design is implemented as a RFID reader antenna on the industry inventory control and supply chain application.
Similar Simulation and design for 3D RFID application
  • ABSTRACT: Based on transformer antenna theory, this paper first presents an analytical model for near-field magnetic coupling incorporating transformer inductance coil system. Formulae are derived for the self inductance and mutual inductance characteristics at the reader antenna. The paper then describes how this model and electromagnetic simulation are used for the design of a prototype three dimensional (3D) RFID antenna application as well as the results achieved.
For $ IEEE paper 3-D and package-conformal UHF RFID antennas with enhanced performance
New UHF Tag Uses 3-D Antenna
  • ... The tags are made with Atmel's ATA5590 chips, which have 1 kilobit of read-write memory and come housed in a shock-resistant thermoplastic casing that resembles a small chocolate bar and measures 135 by 30 by 8 millimeters. The interior of the tag's injection-molded housing has been given a laser-structured metal coating to create a three-dimensional conductive structure that works as an inverted-F antenna and is assembled with an RFID chip.
Phliips app note - 2D focus mifare ® (14443A) 13.56 MHz RFID Proximity Antenna - 2002
Questionable patent for 3D spherical field with two antennas here
Another3D patent
ADDED:
Coupling -
If the master and slave (= transmit-receive coil and tag) coils are flat coils that are essentially 2D with some thickness, then
Optimum coupling occurs when
  • their planes are parallel,
  • they are on the same central axis and
  • close together.
You will get decreased coupling if you move them
  • further apart along the central axis (planes still parallel)
    OR
  • if you slide one across its plane in any direction so they are not on the same axis
OR
  • if you rotate one around its X and/or Y axis
OR
  • Any combination of the above three.
If the plane of your tag coil is almost perpendicular to the plane of your "pickup" coil you have near worst case orientation.
ie the magnetic field vector is at right angles to the plane of the coil so to maximally couple the two coils the sens and receive coils need to be parallel.
  • \$\begingroup\$ Do you mean wind it into more of a short cylinder. Right now it's more of a flat donut I believe...The Microchip design guide link above is great. It states that for best performance/readability the magnetic field should perpendicular to the plane of the tag. I think that most of the time, the tag is perpendicular. I don't think it ever ends up in parallel to it...it may be close...I'll have to check with the team that worked on this product. \$\endgroup\$ – milesmeow Feb 17 '12 at 18:23
  • \$\begingroup\$ If there are two flat coils then optimum coupling occurs when their planes are parallel, when they are on the same central axis and close together. You will get decrease coupling if you move them further apart along the central axis (planes still parallel) OR if you slide one across its plane in any direction so they are not on the same axis OR if you rotate one on X and/or Y axis OR any combination of these three. || If the plane of your tag coil is almost perpendicular to the plane of your "pickup" coil you have near worst case orientation. \$\endgroup\$ – Russell McMahon Feb 18 '12 at 9:10
  • \$\begingroup\$ The magnetic field of the reader coil is perpendicular to the coil of the tag when the tag rests in the same plane as the reader coil. Yes? \$\endgroup\$ – milesmeow Feb 19 '12 at 8:27
