I designed the first version of a PCB board based on atmega328p to control 2 proportional valves (valves specs: V = 12Vcc, R = 3.7 Ohm, I = 1.80A, PWM 120Hz).
Currently, I'm using a FQP30N06L (datasheet) which is a N-Channel QFET MOSFET with a logic level gate allowing voltages in the 3-5v range.
The FET is working fine, but sometimes the atmega resets and so I'm designing again the board in order to improve the circuit (decoupling caps, mosfet IC drivers, ground plane, optoisolators, isolated power supply for the atmega).
At this step, I'm trying to control the MOSFET with a IC driver and I was thinking to use this driver MCP1407 (datasheet).
Is this driver suitable for my FET?
I never used a driver, how do I have to wire it?
At the moment, I directly connect the FET to the arduino output in this way.
connections with the N-FET
As you can see in the photo, the MCP1407 has 5 pins and I am a little bit confused.
MCP1407 IC driver
  • Pin 1: arduino pwm output
  • Pin 2 and 4: arduino GND
  • Pin 3: ?? what is VDD? Is it the main power (in my case 12VDC?)
  • Pin 5: FQP30N06L MOSFET gate
Can you help me, please?
Is the MCP1407 a good driver for this MOSFET?
If not, can you suggest me a good driver for my FET, please?
Do I have to use any resistors between the atmega328p output and INPUT pin 1 and between OUTPUT pin 5 and the MOSFET gate?
Thank you!
EDIT 1:
Are these connections correct? There are duplicate pins, how to handle the two outputs? Do I need to wire both of them to the mosfet gate or I need to leave one floating?
  • \$\begingroup\$ Have you seen the functional block diagram in the datasheet yet? \$\endgroup\$ Nov 3, 2016 at 20:40
  • \$\begingroup\$ Yes, but I'm not an expert. I think VDD is the main power, in my case it is +12VDC. Is it correct? \$\endgroup\$ Nov 3, 2016 at 20:45
  • \$\begingroup\$ I edited the post since I forgot to say that the PWM is at 120Hz. I've carefully read the datasheet and it suggests to place capacitors between GND and VDD and also between GND and OUTPUT. Anyway, VDD should be connected to 12V or to 5V? he FQP30N06L MOSFET is switched ON by less than 5V.. \$\endgroup\$ Nov 4, 2016 at 0:42
  • \$\begingroup\$ I added a schematics. Can you tell me if it is correct, please? \$\endgroup\$ Nov 4, 2016 at 17:57
Pin 6 and Pin 7 should be connected together sine both output must be used. Pins 1,8 and 4,5 need decoupling capacitors as specified by the datasheet.
