I am trying to understand the process of creating combinatorial circuits. I understand that first we document the inputs and outputs, then create minterms and max terms, then push them into a k-map and get a function as an output. This function can then be implemented using logic gates.
The problem I have is, I don't understand the logic behind converting the equation that we got, such that I can implement the same circuit using just NAND or nor logic gates.
The image is from my book for converting a half adder circuit. I understand the steps taken but don't understand the reason why they took them. Thanks for the help.
