10
I was learning about voltage dividers from here, and I decided to try a test circuit with my Radioshack learning lab. With an input voltage of 4.5V and two 1000Ω resistors, I expected the voltage output would be 4.5*(1000/(1000+1000)) = 2.25V.
After looking at this, I thought that the only way to measure the voltage output from the divider was to measure the voltage drop of a resistor (otherwise I'd just get a 0V reading), so I added a 1000Ω resistor to the circuit (R3 in the drawing below). I measured the voltage across this extra resistor, but I got 1.48V for an output voltage. What I found odd was that when I used higher-resistance resistors, the voltage drop output got closer and closer to 2.25 V (the highest I did, 1MΩ, led to the 2.25V reading I wanted).
Can I use resistors like this R3 to test the voltage output coming out of this voltage divider? If not, how can I check by measurement that this voltage divider gives an output of what I'm sure is 2.25V?
    \$\begingroup\$ Your 1k resistor R3 now means that the bottom resistor in the potential divider is R2||R3 = 500Ohms. Why not just stick the multimeter directly across R2? \$\endgroup\$ Nov 5, 2016 at 21:56
  • \$\begingroup\$ @TomCarpenter Oh, that didn't occur to me. Sorry, I'm still getting used to a multimeter and measuring with it. I can accept your comment as an answer, thanks. \$\endgroup\$
    – DragonautX
    Nov 5, 2016 at 22:00
    \$\begingroup\$ You've changed the circuit by adding the extra resistor. So now it's no longer a potential divider with two 1000 ohm resistors. \$\endgroup\$
    – user253751
    Nov 6, 2016 at 4:31
  • \$\begingroup\$ This is a good "beginners" question. The OP is learning how circuits are affected by other parts, and it leads into understanding input and output impedances, loading and so on.. I have nothing to add to the excellent answers here hence the comment. \$\endgroup\$
    – Ian Bland
    Nov 11, 2016 at 10:21
5 Answers 5
16
Welcome to resistive potential dividers, if you load them, they change.
You performed a calculation with R1 and R2 forming the potential divider to find the output voltage. However now you are adding in an extra resistor R3. That means that the lower resistor in the potential divider is now actually R2||R3 (R2 in parallel with R3).
In the case of you schematic example, you now have a bottom resistor in the potential divider of R2||R3 = 500Ohms. This is very different from the value you calculated with in the first place. If you repeat the calculation again, you get:
$$V_o = V_i\times\frac{R_2||R_3}{R_2||R_3 + R_1} = 4.5\times \frac{500}{1500} = 1.5V$$
close to what you measured.
As you make the resistor larger and larger, the affect it has becomes less and less - you can see that from the calculation of R2||R3 - the larger you make R3, the closer to R2 the combined value becomes.
It's worth noting at this point that if you omit R3 and simply connect the multimeter across R2, you will actually have the same issue. A multimeter in voltage mode is basically a very large resistor, so if you connect it to your circuit it will still have a loading effect - in essence it becomes R3. However the multimeter resistance is very large (usually >10MOhm), so it will have a very small affect on your circuit.
Simply remove R3. The multi-meter already has a very high input resistance.
  • \$\begingroup\$ Can you give a bit more explanation of what that is doing? Also, are you expanding on what Tom said above? \$\endgroup\$
    – Kortuk
    Nov 6, 2016 at 9:29
You are correct, that you want to "measure the voltage drop of a resistor". However, R2 is that resistor. You don't need to add anything--just measure the voltage drop across R2.
The best way to test a voltage node accurately, is with a "high" input resistance prove. This can be an oscilloscope prove or a 10Megohm voltmeter. Although the voltmeter you are using is not very good, the main reason you are not seeing the voltage you expect, is that you have another resistor (R3) across the resistor (R2) that you are measuring. The accuracy will improve if you remove R3.
You're trying to use/misuse a memorized formula, when all you need is Ohm's Law. Think of it this way: a current flows from BAT1 and goes through R1. Then it splits in 2. Exactly 1/2 goes through R2 and the other 1/2, through R3. Since R2 and R3 each see half as much current as R1, the voltage across the pair is half that across R1. This means the voltage across them is also 1/2 (Ohm's Law) the voltage across R1, or 1/3 of BAT1's voltage. The voltage is/should be 1.5 V.
The equivalent resistance of parallel resistors can also be found by application of Ohm's Law. After some algebra, you'll find it's equal to the product over the sum of the resistor values. R2 and R3 together look like 500 ohms.
