I'm trying to connect raspberry pi with stm32f103 over SPI where stm is a slave.
I'm not really like SPL and also I found awesome cmsis drivers for peripheral from Keil so I decided to use them.
Well, the problem is that I can't send any data to RPi. Reading works nice: everything I send from RPi is caught by STM but nothing is on the MISO line.
Here is my SPI initialization and some used definitions:
#define FRAME_START_POS 0
#define FRAME_TYPE_POS 1
#define FRAME_DATA_POS 2
#define FRAME_START_BYTE 0x1B
#define FRAME_TYPE_START 0x01
#define FRAME_TYPE_DATA 0x02
#define FRAME_HEADER_SIZE 2
#define RPI_SPI Driver_SPI2
void SpiInit(void)
out_data[FRAME_START_POS] = FRAME_START_BYTE;
out_data[FRAME_TYPE_POS] = FRAME_TYPE_DATA;
if(RPI_SPI.Initialize(RpiSpiCb) != 0)
LOGGING_Error("Can not initialize SPI");
if(RPI_SPI.PowerControl(ARM_POWER_FULL) != 0)
LOGGING_Error("Can't set SPI power");
int status = RPI_SPI.Control(ARM_SPI_MODE_SLAVE |
ARM_SPI_SS_SLAVE_HW |
ARM_SPI_CPOL0_CPHA0 |
ARM_SPI_DATA_BITS(8U) |
ARM_SPI_MSB_LSB, RPI_SPI_BUS_SPEED);
if(status == -1)
System_ErrorLedOn();
LOGGING_Error("Can't set SPI control");
static void transfer_headers(void)
* out_data[0] and out_data[1] are never seen
* on the MISO line but in_data is filled.
if(RPI_SPI.Transfer((void*)out_data, (void*)in_data, FRAME_HEADER_SIZE) != 0)
LOGGING_Error("Can't transfer data over SPI");
state = READ_HEADER;
I can't find out what I'm missing here. Maybe sending data when you are a slave is tricky but I haven't found anything about that?
P.S. Using RPI_SPI.Send()
instead of Transfer()
also does not work.
UPDATE
Here is function that is used to send data from RPi:
def __send_data(self, data):
ans = self.stm.xfer2(data)
if ((ans[FRAME_START_POS] != FRAME_START_BYTE) or
(ans[FRAME_TYPE_POS] != FRAME_TYPE_DATA)):
raise IOError("Wrong bytes in header from stm: 0x%02x 0x%02x" %
(ans[FRAME_START_POS], ans[FRAME_TYPE_POS]))
if len(ans) > FRAME_HEADER_SIZE:
return ans[FRAME_HEADER_SIZE:]
return []
