I am trying to plan a graphics processor project that will only render lines. It will use the bresenhmam's line algorithm. After reading on the algorithm, it makes sense how it works to calculate locations of pixel that make up a line. What is not clear is how will this be output to a screen. Perhaps, the data will likely be stored into an external memory, but the obvious way to do so appears highly inefficient.
Assume I have 10 lines. I calculate the pixel values that make each of these lines, do I store these pixels into some internal FIFO for "dispatch"? Then another part of the design reads the pixel values to be "dispatched", calculates what location to store them in memory and writes them to memory. This has to do be done for each line meaning that a memory location may be read and written multiple times for a single frame if multiple lines pass through nearby each other. Is this correct? If so, then as the number of lines to draw increases, it will be harder to write full frame to memory by rendering all lines before the next frame has to read out since frame rate for video display is fixed.
This means there is no way to go from top left screen pixel to bottom right and find out if a given pixel is part of a line. I can't find a simple explaination for how to implement frame buffer for this type of system.
