I am using STM32F4 series MCU with STM32CubeMX enviroment. I can send and receive data without problem in RS232 physical layer.
My problem is that when I use with it in RS-485 physical layer, I should know when transmission process is finished, last bit is sent from shift register and I am ready to terminate transmit function and enable receive function of RS-485 chip.
What is the flag convention of UART_Busy_Flag or related flag with this process.
    \$\begingroup\$ You need to look for the Transmission Complete (TC) bit and the Transmission Complete Interrupt Enable bit (TCIE). \$\endgroup\$
    – Steve G
    Nov 7, 2016 at 17:37
You should use the following function:
HAL_StatusTypeDef HAL_UART_Transmit_DMA(UART_HandleTypeDef *huart, uint8_t *pData, uint16_t Size)
and make sure that the UART and the DMA interrupts are enabled.
If you look into the implementation, (only a part of it):
/* Set the UART DMA transfer complete callback */
huart->hdmatx->XferCpltCallback = UART_DMATransmitCplt;
/* Set the UART DMA Half transfer complete callback */
huart->hdmatx->XferHalfCpltCallback = UART_DMATxHalfCplt;
/* Set the DMA error callback */
huart->hdmatx->XferErrorCallback = UART_DMAError;
/* Enable the UART transmit DMA Stream */
tmp = (uint32_t*)&pData;
HAL_DMA_Start_IT(huart->hdmatx, *(uint32_t*)tmp, (uint32_t)&huart->Instance->DR, Size);
The DMA will be started in IT mode, and there are three HAL_UART callbacks which will be called by the callback functions above.
  1. Transmit complete callback: HAL_UART_TxCpltCallback
  2. Half of the bytes are sent: HAL_UART_TxHalfCpltCallback
  3. Error: HAL_UART_ErrorCallback
All of these have weak declaration so you have to implement them. For example:
void HAL_UART_TxCpltCallback(UART_HandleTypeDef *huart)
    if (huart->Instance == USART1)  // change USART instance
       // Transmit complete handle RS-485 related stuff
  • \$\begingroup\$ But in the Normal mode I get some problem with using, this is usefull in circular mode \$\endgroup\$
    – gogogo
    Jul 9, 2021 at 12:21
