Now I have a homework question that isn't quite clear to me.
"Construct a finite state machine that accepts a base 2 value entered one bit at a time with the most significant bit first. The machine output is 1 if the number entered so far (i.e. current state) reflects 2 mod 3 else the output is 0."
now I would have to build a truth table as well as a logical circuit.
I'm confused at where it says 1 bit at a time with the most significant bit first. So the most significant bit would be 1 in base 2, but would I not have to use more than one bit per cycle to structure this? So would this be an error in the question, or am I missing something.
Thanks in advance
    \$\begingroup\$ I can't fault you for being confused. It is a very academically ( poorly) defined problem, not a reality based one. \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Nov 11 '16 at 3:04
Ok, here is more detail. The state diagram for implementing this as a Moore machine looks like this; enter image description here A Moore machine is one where that states are the outputs. I always remember this as Mealy machines are more complicated. From this state diagram the next state and excitation tables can be created. They look like this; enter image description here
Karnaugh maps for each J and K input are used to come up with the logic. The logic can be seen in this schematic; enter image description here A simulation of this schematic shows an input string that causes the machine to go from state 0 to 1 and back to 0 starting at 2us. So X = 1,1,0. Starting a 6us the machine goes from 0 to 1 to 2 and stays there for X = 1,0,1,1. At 10 us the machine goes from 2 to 1 to 0 for the inputs 1,0. This has exercised all the transistion possible. Here is the simulation output; enter image description here
| improve this answer | |
When reading a number, MSB first, you only need to keep track of the previous value modulo 3, not just the overall previous value, which is easily achievable with a simple transition table and three states. If input is zero, the following transitions can be shown to occur:
  • 0 -> 0
  • 1 -> 2
  • 2 -> 1
If the input is 1, the following transitions occur instead:
  • 0 -> 1
  • 1 -> 0
  • 2 -> 2
according to the rules of modular arithmetic.
  • \$\begingroup\$ Thanks, I don't want to tie you up too much, as our prof never really went into specifics. So would this be ideal imgur.com/zdrg8jM \$\endgroup\$ – 1011 1110 Nov 8 '16 at 3:41
  • \$\begingroup\$ @JoshBarber It should be, but you might want to make output 1 for both "b" cases. \$\endgroup\$ – nanofarad Nov 8 '16 at 15:28
