In my board, all 0402 parts are using gang solder mask.
The pad to pad distance is 10 mils. Is there any risk of solder short?
Do I need to suggest applying solder mask web between the pads for all 0402?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityIn my board, all 0402 parts are using gang solder mask.
Mentor Graphics LP viewer based on IPC has the nominal pad edges just 0.39 mm apart for a RESC1005X40N. Our normal target is a 0.1 mm gap for copper pad to the resist, I reduced this to 0.0957 mm for my 0402 to maintain a 0.2 mm resist sliver.
Just my solution of course.
