I am currently developing a circuit that 16 LDRs, 4 LM339N ICs and 1 PIC16F877A. I compare outputs of LDRs with an adjustable reference voltage. I achieved getting 0-5 V from LM339N. Now I send these values to 16F877A as digital inputs to check if one of them is HIGH. If I check only one value, it works well and I can get voltages between 0.12-5.01 V from digital output pin. But when I increase digital inputs to two or more, digital output gives 2.1 when it is low and 2.5V when it is high and it is not enough for me. I have tried defining;
TRISB = 0xFF;
TRISC = 0xF0;
TRISD = 0xF0;
reading values between RB0-7, RC4-7, RD4-7 and writing output to RD0. I have also tried neglecting ADC module and;
TRISB = 0xFF;
TRISA = 0x00;
reading values from RB0 and RB1 and writing to RA0. But no luck yet.
I am using 8 MHz HS crystal with two 22 pF capacitors. Pin 1 has a resistor with push button. PIC is supplied with 5.1 V from 11-32 pins and ground is connected to 12-31 pins. I don't have any prepared circuit diagram but if I cannot find any support from here, I can build it. I am using MPLAB X IDE v3.45 and PicKit2 for programming. The code is included below.
#define _XTAL_FREQ 8000000
#include
// BEGIN CONFIG
#pragma config FOSC = HS // Oscillator Selection bits (HS oscillator)
#pragma config WDTE = ON // Watchdog Timer Enable bit (WDT enabled)
#pragma config PWRTE = OFF // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOREN = ON // Brown-out Reset Enable bit (BOR enabled)
#pragma config LVP = OFF // Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit (RB3 is digital I/O, HV on MCLR must be used for programming)
#pragma config CPD = OFF // Data EEPROM Memory Code Protection bit (Data EEPROM code protection off)
#pragma config WRT = OFF // Flash Program Memory Write Enable bits (Write protection off; all program memory may be written to by EECON control)
#pragma config CP = OFF // Flash Program Memory Code Protection bit (Code protection off)
//END CONFIG
void main(){
ADCON1 = 6;
CMCON = 7;
TRISB = 0xFF;
TRISA = 0x00;
RA0 = 0;
while(1){
if(RB0 == 1){RA0 = 1;}else{RA0 = 0;}
__delay_us(5);
if(RB1 == 1){RA0 = 1;}else{RA0 = 0;} // Works well when I comment this line.
Also tried building if/else if/else structure, not working too. Thanks in advance.
