My headphones all of a sudden stopped working in one ear, then both. Same old story, I cut open the plug saw 5 wires (it's a TRRS plug, mic and button + headphones). The wires are
  1. Red (Right Of course)
  2. Blue (Left of course)
  3. Golden (ground of course)
  4. Green (no clue)
  5. Golden and Blue twisted together (no clue)
Just to start off, I stripped the wires, burned the enamel coating, and re-soldered the Red, Blue and Golden wires to old jack only as below-
P.S - picture just for reference
plug wiring
  1. Blank
  2. Ground
  3. Red
  4. Blue
Plugging in the headphones to my laptop (which has a combo 3.5mm jack) I can hear sound on both earcups, but the sound is extremely low. My soldering is pretty shabby, so I'm suspecting that my bad soldering has increased the resistance so much that sound is low, but I'm not sure.
Why is the volume so low and how may I fix it?
  • \$\begingroup\$ You should check the resistance between each end of the wires, in case the wire itself is broken inside. If the resistance measurements are all low then check the resistance between the wires and the barrel. Or it might be simpler to do those checks in the reverse order if it is difficult to get to the headphone end of the wires. \$\endgroup\$ Commented Nov 9, 2016 at 18:33
  • \$\begingroup\$ Why don't you check the impedance with a volt meter (a good one and make sure you account for contact resistance) most manufacturers will list the headphone impedance. \$\endgroup\$
    – Voltage Spike
    Commented Nov 9, 2016 at 19:20
  • \$\begingroup\$ @laptop2d I tried, but my meter didn't show up anything \$\endgroup\$
    – YaddyVirus
    Commented Nov 9, 2016 at 19:24
  • \$\begingroup\$ Shouldn't the GND wire be connected to pin1 (the most outer)? \$\endgroup\$
    – Nazar
    Commented Jan 10, 2017 at 14:57
  • \$\begingroup\$ @Naz Idk... I gave up on those headphones and threw them in the trash... \$\endgroup\$
    – YaddyVirus
    Commented Jan 10, 2017 at 18:21
I just have fixed such issue several days ago. Most probably you have issue with ground wire being broken. Sound is low level because now, without ground wire, you have two speakers connected in series.
  • \$\begingroup\$ So I just strip the ground wire a but more, burn the enamel and sold it again right? \$\endgroup\$
    – YaddyVirus
    Commented Nov 9, 2016 at 19:26
