I am newbie here , if i posted wrong site i am sorry :)
I have bought discovery board to learn arm programing , but when i plug board to laptop via usb, there is no sign of 'device plugged' even on the device manager ,one of the leds on the board near the usb ports blinking , another one just on.
    \$\begingroup\$ Did you install drivers, and have the pins shorted correctly on the board so the USB is used? \$\endgroup\$ – Eric Johnson Nov 10 '16 at 2:05
    \$\begingroup\$ Which USB port do you use? The mini or the micro? \$\endgroup\$ – Bence Kaulics Nov 10 '16 at 10:23
    \$\begingroup\$ Look at section 4 in this document: st.com/content/ccc/resource/technical/document/user_manual/e9/… \$\endgroup\$ – Eric Johnson Nov 10 '16 at 10:24
    \$\begingroup\$ @BenceKaulics ,the mini one \$\endgroup\$ – Celosad Nov 10 '16 at 10:25
    \$\begingroup\$ Did you try in all of the USB ports of your laptop? \$\endgroup\$ – Bence Kaulics Nov 10 '16 at 10:27
-1
İ have figured out that problem is occured because of usb cable that did not have data line inside , thanks for for your replies
