I'm using an Charge Pump Inverter,MAX899R in free run mode with switching frequency of 500kHz like in the circuit attached. The problem is that I'm seeing a lot of switching noise in the output, much more than i expected as it is visible in the figure attached. Moreover the noise has a frequency of 1MHz, and not 500 KHz, is this normal ? How could i fix the problem ?
Update After a suggestion of AndyAka, I checked the ground and it has the noise I'm seeing in the output, I read it would improve to use a ferrite bead after GND and after VCC but no improvements. I'm adding 3 more pictures with the noise at the ground(fig1), noise in the VCC with osciloscoppe earth probe closer to C11(fig2) and the noise in VCC with earth probe closer to C20.
