I have the relay you see here:
Picture of relay contacts
How do I read that diagram - or specifically, which contact is the common, normally open, and normally closed contact?
  • \$\begingroup\$ this should explain it all glolab.com/relays/relays.html \$\endgroup\$ Commented Nov 10, 2016 at 19:46
    \$\begingroup\$ I would read that drawing on the PCB as indicating the center as Common, left is NO and right is NC. \$\endgroup\$
    – brhans
    Commented Nov 10, 2016 at 19:49
  • 8
    \$\begingroup\$ And to avoid any confusion, get your multimeter out, switch it to continuity test and measure it. \$\endgroup\$ Commented Nov 10, 2016 at 19:51
    \$\begingroup\$ The middle pin is always connected to the pin on the right [NORMALLY CLOSED], whenever the relay is turned on this middle pin is connected to the pin on the left [NORMALLY OPENED]. You should definitely test this using a multi-meter. I remember buying a relay module from a Chinese vendor and this drawing was wrong ! \$\endgroup\$
    – Elbehery
  • \$\begingroup\$ Relays are always shown with the power off, so NO/Com/NC left -to-right As FakeM & @Elbehery say, confirm with your multimeter. \$\endgroup\$ Commented Nov 10, 2016 at 19:59
7
  1. Left terminal: Normally Open
  2. Center terminal: Common
  3. Right terminal: Normally Closed
Confirm by measurement.
  • \$\begingroup\$ That is how I would read it too, and it makes sense knowing that the common pinout of a cheap relay has the common pin in the center (between the coil pins) but there is a chance it could have been routed by a fool (or because of a strange pinout of the relay, which that kind isn't, so it would have to be the "fool" option) so that the right-hand terminal is common. So yes, the most important thing is to test it by measurement. See which terminals are connected by "buzzing" it with a DMM with the relay switched in both positions. \$\endgroup\$
    – Majenko
    Commented Nov 10, 2016 at 20:37
  • \$\begingroup\$ You could also confirm it by looking at the data sheet for the relay and follow the (likely very simple) traces on the bottom of the PC board. \$\endgroup\$ Commented Nov 10, 2016 at 20:40
I recently laid a board out with the exact same relay + header arrangement. Due to the pinout of the relay the simplest way of routing the traces results in the pinout given by @RichardCrowley.
Here is a render of the portion of the board with the relay header:
And this is the PCB traces of that section:
You can probably find the same trace layout on your board, or at least confirm which pin is connected to which connection on the terminal block using a DMM in continuity (aka "Diode") test mode (the mode that goes beep when you touch the probes together).
  • \$\begingroup\$ Nice (I guess the clearance to the pour could be greater) Did you stitch traces both sides with vias or are the white dots just silk? \$\endgroup\$ Commented Nov 10, 2016 at 21:59
    \$\begingroup\$ Stitched. The clearance is well within tolerance, though I did consider clearing right to the edge of the board. \$\endgroup\$
    – Majenko
    Commented Nov 10, 2016 at 22:00
