I've used the Place>Soild Region command to create polygon traces for my board. However when I highlight the traces by hovering over and pressing shift. The Net is connected but the highlight does not include the polygon I made. I think I'm doing polygons in the wrong way. If I do Place>FillI can only make rectangles but it does highlight all the correct regions.
Here is an example of Place>Soild Region not being a part of the highlighted trace connections.
  • \$\begingroup\$ Can you just edit the polygon and assign your desired net to it? \$\endgroup\$ – mkeith Nov 12 '16 at 17:56
Try Place -> Polygon, not Place -> Solid Region
The polygon dialog comes up and you can give it a net.
|improve this answer|||||
  • \$\begingroup\$ You can also edit the net in the properties window. \$\endgroup\$ – Daniel Nov 12 '16 at 17:58
