Considering that the SDR board has one TX/RX output/input and one RX input, I am wondering how could I use one antenna for a half duplex communications on the same frequency.
The idea is to use the TX/RX output for transmitting and the RX input for receiving. The problem is that the required output power is around 47dBm (which is achieved after a HPA) and if I use a fairly good circulator (for joining Rx with TX) as this one, it gives a 20dB isolation and that is not enough as it would burn the whole thing with the reflected power (max. input power of the SDR is -15dBm after the LNA!). Scheme:
As an alternative, I have thought of using a electronically controllable switch that could open one path while closing the other. The problem with this option is that so far I have only found very expensive solutions and my budget is limited.
Can anyone give me some guides on building a PC controllable switch for this purpose (should withstand around 50W of power while offering the typical 50\Ohms of impedance)?
Otherwise, any different ideas/approaches on how could I solve the problem?
