My transfer function is \$\frac{4s + 2}{s(s-1)(s+2)} \$
Given that there are 3 poles and 1 zeroes, the amount of loci going to infinity is 3-1 = 2 loci = r. I calculated where the centroid of the asymptotes should be begin. The equation is the (sum of poles - sum of zeroes)/r = location of centroid on real axis. The centroid location I got was -.25, so I can't understand why MATLAB plotted the root locus otherwise. Given that there are 3 poles, there are to be 3 asymptotes. (1 on the real axis and 2 going off the opposite direction.) I illustrated the supposed asymptotes in black in the following image.
My problem is that the calculated asymptotes do not match up with my expectations. My calculated asymptotes are clearly not what MATLAB has calculated. Why and how so? I also did an angle computation using the formula (2q + 1)/r.
