I was working on TI CC2530 and wanted to flash the chip with using USB mini cable without using CC debugger. would this be possible? and if yes, then what steps do I need to follow.
    \$\begingroup\$ It's called a bootloader, which if you would have read the datasheet and other attendent app notes, you would have learned about all the ways you could boot this chip. \$\endgroup\$
    – Voltage Spike
    Nov 15, 2016 at 17:06
It is possible to make a flash bootloader in the CC2530 - so that it will update its own flash with a program received over the USB link (or even by over the air).
But the CC2530 is not supplied with a Bootloader installed - so the first time you program the device you will need the CC debugger.
If you want to make your own version of the CC debugger that is also possible, the protocol is detailed here:
http://www.ti.com/lit/ug/swra124/swra124.pdf
