The diffusion current density due to diffusion of electrons is given by: Jn=(e)(Dn)(dn/dx) The diffusion current density due to diffusion of holes is given by: Jp=-(e)(Dp)(dp/dx)
I understand that for a semiconductor, Electron diffusion current density and hole diffusion current density are opposite to each other.So they will have the opposite sign. But why is electron diffusion current positive and hole diffusion current negative?(despite the fact that electron charge is -ve and hole charge is +ve)
  • \$\begingroup\$ Err, the charge is negative ? \$\endgroup\$
    Nov 15, 2016 at 18:20
  • \$\begingroup\$ Because Ben Franklin got it wrong www-spof.gsfc.nasa.gov/Education/woppos.html \$\endgroup\$ Nov 15, 2016 at 18:27
  • \$\begingroup\$ Electron current versus Conventional Current is confused a lot when we talk about semiconductor and electrons flow. So it is simply a matter of how you interpret the problem. Electron current should be used in this case. \$\endgroup\$
    – 12Lappie
    Nov 15, 2016 at 19:07
Diffusion happens because of an unequal concentration of carriers. Carriers diffuse from the higher concentration to the lower concentration. The change of concentration is described by a gradient which points in the direction of the higher (!) concentration. In other words they move in the direction of the negative gradient.
This is where the additional minus sign comes in so that the current becomes positive.
  • \$\begingroup\$ Sir thank you for explaining so well. Sir I would like to ask a basic question. If the concentration of p is given by p(x)=e^(-x), then Jp will be positive, ie hole current density will be in the +ve x direction. On the other hand, if p is given by p(x)=e^(x), the hole current density will be negative implying diffusion of holes in the negative x direction. \$\endgroup\$
    – Soumee
    Nov 16, 2016 at 15:37
  • \$\begingroup\$ Sir can you help me with this question electronics.stackexchange.com/q/313330/115973 \$\endgroup\$
    – Soumee
    Jun 28, 2017 at 9:57
Since the graph of concentration is a negative gradient,the diffusion current due to electrons has negative sign. Considering the negative gradient, it becomes positive
The diffusion current due to holes has a positive sign. Considering the negative gradient, it becomes negative.
