-1
for one of my projects I'm trying to create a solar assisted drone.
So far this is my schematic:enter image description here
So with the battery itself connected to the flight control board, the drone runs for about 6 minutes. The problem that I'm having is that the battery when fully charged is at 4 V and the Solar Panel at 3 V, the panel experiences precisely 1 V of reverse current. When we hook up the panel and the battery together to the flight control board, I get about 2 minutes of flight time.
The drone needs a minimum of 3.2-3.3 volts to fly, and I thought about using a resistor or another diode to bring the voltage of the battery down to a greater equilibrium with the panel, but I don't want to cut on the voltage too much since it will decrease flight time. Is there anyway that you can think of could work to wire it to prevent the reverse current?
Your help, input and any advice is greatly appreciated.
(P.S. I'm using pigtails on the battery, panel and the node for easier attachment. I wonder if this could also be a source of error somehow...).
  • 4
    \$\begingroup\$ Given the efficiency of solar cells, wouldn't the added weight of the cells only lessen the flight time? \$\endgroup\$ – Bort Nov 15 '16 at 21:40
    \$\begingroup\$ The battery capacity and the flight time tell you the current needed : 3.3A. The solar cell provides about 6% of that so even if you overcome all the problems (including the losses in the diodes) it can only extend the flight time by 6% - or about 20 seconds. Allow for the cell's weight and even meeting te original flight time is optimistic. \$\endgroup\$ – Brian Drummond Nov 15 '16 at 21:45
    \$\begingroup\$ No. Measure the flight time, add the cell (disconnected, just for the correct weight) and re-measure. \$\endgroup\$ – Brian Drummond Nov 15 '16 at 22:32
    \$\begingroup\$ @AngelaAlbrecht considering the very meagre extension on flight time you would get even if the solar cell didn't weigh anything, you'd obviously fare better with a second battery. \$\endgroup\$ – Marcus Müller Nov 15 '16 at 23:09
    \$\begingroup\$ the capacitors simply don't "produce" any energy. so, they'd be nothing but added weight. \$\endgroup\$ – Marcus Müller Nov 16 '16 at 8:36
Your solar cell certainly adds more weight than it adds energy for flight. So even under the assumption that the added solar cell's weight did not decrease the duration of flight, the 6% extension in power is probably not worth it.
To put this short: what you need is a power source with a very high power density, i.e.\$ \frac{\text{W}}{\text{kg}}\$. Consumer/tinkerer-grade solar cells are not good in that respect, at all. You'll notice that there's not a single commercial aircraft/helicopter/UAV that uses solar cells, for exactly the same reason (It's really not that airlines wouldn't try to reduce fuel consumption – it's their main cost factor). Strapping a lot of very expensive high-efficiency solar panels on an aircraft works for sailplane-like ultra-light planes, but those are aeronautical designs that, by themselves, without consuming any energy, can fly for hundreds of kilometers before having descended 100m. For those planes, getting just a little more energy out of the solar cells than it costs to lift them up is OK. Quadrocopters are a completely different kind of beast; if you throw an unpowered quadrocopter up, it comes crashing down. A sailplane will sail for minutes (much like a paper airplane vs a paper model of a quadrocopter).
Lithium ion batteries are very hard to beat regarding density. In other words, whatever you come up with will work worse than just adding a second battery.
Excourse into fuel efficiency
That's really not your fault – it's just the physics of things that must leave ground that flight efficiency is very directly related to energy density of the power source. If you want to look at a case where that's catastrophically true:
The Tsiolkovsky rocket equation is a formula that describes the problem that a rocket needing to escape earth's gravity will need fuel to achieve that.
That's why for rocket fuel, they usually don't use cheap, easy to handle things like Kerosene in the later stages.
Although, for example, in the sixties, they used a very highly refined Kerosene/liquid oxigen mix for the first stage of Saturn V, the second and third stage use Liquid Hydrogen, which is and was very expensive, but has great energy density, as you can probably imagine; modern rockets used for commercial spaceflight tend to use liquid Hydrogen and funky and slightly dangerous chemicals like Monomethylhydrazine, because the overall power per kg is optimal for such fuels includingt he necessary tanks and engines.
| improve this answer | |
  • \$\begingroup\$ A funny mixture of cryonic rocket fuels like LOX and LH2 and hypergolic fuels like hydrazine and nitrogentetroxide. Hydrazin is not only slightly dangerous, it is toxic, carcinogenic and of course explosive. \$\endgroup\$ – Uwe Nov 16 '16 at 16:30
  • \$\begingroup\$ @Uwe admittedly, slightly was an understatement. But yeah, I'd expect everyone to have the common sense to stay away from rocket fuel unless they know what they're doing. \$\endgroup\$ – Marcus Müller Nov 16 '16 at 22:28
Solar assisted flight is possible if you choose the right aircraft, read here https://en.wikipedia.org/wiki/Solar_Impulse But Solar Impulse is an aircraft with wings optimized for small electric power consumption. Aircrafts without wings like helicopters or drones need to much power for the use of solar cells. Forget the drone and use a sailplane model with a small electric motor. But you will need very thin and flexible solar cells that would fit to the wings smoothly. For your drone, you would need a solar cells with at least 1 A current, better 2 A. The voltage under load must be a little bit greater than the voltage of the battery. But such a solar cell is too large and heavy for the drone. The result would be a drone running for about 9 instead of 6 minutes down at the ground and unable to fly or even lift some centimeters for seconds.
  • \$\begingroup\$ It has been done before, although on a smaller scale and completely solar. 1). youtube.com/watch?v=HjhCrllZ7Tg 2). diydrones.com/profiles/blogs/… \$\endgroup\$ – Angela Albrecht Nov 17 '16 at 20:13
  • \$\begingroup\$ Diydrones is not completly solar. The battery has 2.2 AH and the solar cells 1 A. If we assume a flight time of 10 minutes with battery only, the current is some 13 A. With solar cells it will be about 11 minutes, not more. But the additional weight may reduce flight time. \$\endgroup\$ – Uwe Nov 18 '16 at 12:56
  • \$\begingroup\$ My mistake, yes it's not completely solar. But the point of my project was to make a solar assisted drone. How did you calculate the time of flight? \$\endgroup\$ – Angela Albrecht Nov 20 '16 at 19:49
  • \$\begingroup\$ @AngelaAlbrecht: the flight time of 10 minutes was only a guess. If 2,2 Ah is unloaded in 10 minutes, the current is 2,2*(60/10)=13,2 A. If 1 A "assisting" current comes from the solar cells, the battery current is 12.2 A. Unloding 2.2 Ah with 12,2 A results in a time of 0.18 h or 10.81 minutes. You may repeat the calculation for a flight time of 15 minutes using the battery only, but the result is not much better. \$\endgroup\$ – Uwe Nov 21 '16 at 15:02
