What is the difference between the two? Why would you use say, 5 volts and 2 amps, over higher voltage and lower amps?
closed as unclear what you're asking by Andy aka, JIm Dearden, Scott Seidman, Voltage Spike, Nick Alexeev Nov 17 '16 at 0:56
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ "Low amps high volts vs high amps high volts?" Don't you mean Low amps high volts vs high amps low volts? so you are comparing equal amounts of power. \$\endgroup\$ – JIm Dearden Nov 16 '16 at 15:52
  • \$\begingroup\$ power engineering vs electronics engineering. High power vs lower power. It takes more power to drive a bigger load generally speaking so higher voltage and current. \$\endgroup\$ – 12Lappie Nov 16 '16 at 15:55
  • \$\begingroup\$ If 5V is what your device needs, it may make sense to provide 5V instead of providing 100V and having additional circuitry at the device to get the required 5V out of the 100V provided. \$\endgroup\$ – JimmyB Nov 16 '16 at 16:06
Going off of your post content rather than the title, I think you are asking why use higher voltage and lower current vs lower voltage and higher current to drive an equal amount of power.
It is often more efficient to use higher voltage and lower current. Wires often have an ampacity rating, which is how much current they are rated to handle. If you double the voltage and keep current the same, you can use the same wire to drive a load twice as big.
However, there are often practical limits to how high of a voltage is used. At higher voltage, certain safety considerations come into play. Wires and other components have voltage ratings, and going above those ratings may cause the electric field to overcome the dielectric strength of the insulation, leading to a loss of insulation and an electrical short.
There are more complex reasons why certain devices, such as microcontrollers, all use 3.3V or 5V. This Quora post has some good explanations. It seems that transistors in use at the time had a voltage drop of 0.7V and many useful combinations of transistors required at least 3V. Also, if these devices use a higher voltage, more space would be required to insulate internal components, or material with a higher dielectric would have to be used which may not be cost effective.
In terms of power, they are frequently equivalent. However there are always larger systemic conditions and constraints.
Higher voltage is often used to send large amounts of power over long distances specifically because the current is lower and there is lower loss through the transmission system (for example in the public power utility grid).
But sometimes it is more efficient to use lower voltage and higher current. For example a car battery. Because of the way batteries work is is more efficient to use large cells capable of 100s of amps because the distance to the load (starter motor) is quite short.
  • \$\begingroup\$ I'm not sure to understand "because the distance to the load (starter motor) is quite short." Does it means that It would not work if they were separated by let's says 5 meters of wires? \$\endgroup\$ – JinSnow Feb 25 at 20:35
