I have bought a PIC16F877A microcontroller and its board before and since then, I haven't used it much because I don't really have enough time and patience to learn C. I was thinking to buy a Netduino since it can be programmed using VB.NET (which obviously I'm familiar with). However, I didn't want to abandon the stuff I bought earlier, so therefore I'm asking if there is a way to program the PIC16F877A using VB.NET, maybe using the SDK provided in the Netduino website?
Thanks in advance.
    \$\begingroup\$ 368 bytes of RAM means that there can never be a VB.NET VM on the PIC16F877A, but let's see if we can get a more detailed answer \$\endgroup\$ – Kevin Vermeer Feb 21 '12 at 18:46
  • \$\begingroup\$ @KevinVermeer I mean, is there a way to program it on VB.NET and maybe a converter converts it to C? Or maybe the same syntax as VB.NET? \$\endgroup\$ – Seif Shawkat Feb 21 '12 at 18:51
  • \$\begingroup\$ I have heard about Pigmeo but don't know much about it, might it be a solution? \$\endgroup\$ – Seif Shawkat Feb 21 '12 at 19:32
    \$\begingroup\$ @KevinVermeer, perhaps the answer here could be educational: electronics.stackexchange.com/questions/26412/… \$\endgroup\$ – Jon L Feb 21 '12 at 19:39
    \$\begingroup\$ @JonL - Yes, that's an excellent answer! Feel free to copy it over and adjust it so that it's applicable here. \$\endgroup\$ – Kevin Vermeer Feb 21 '12 at 20:35
No. However, you can get a BASIC compiler for your PIC16F877A from Micro Engineering Labs. I've used some PIC products built with that.
See http://pbp3.com/download.html -- they have a 15 day free trial, after that you will need to open your wallet.
Good luck with your project.
You can read following link for vb tutorial of Serial port You can have a simple demo here to send data from vb to serial port..later on you can use 8051 or pic microcontroller board to decode it on hardware for leds. http://embeddedtweaks.wordpress.com/2014/10/30/accessing-pc-serial-port-in-visual-basic/
  • \$\begingroup\$ This does not answer the question which was about programming the microcontroller with VB.NET, not the PC. \$\endgroup\$ – David Nov 3 '14 at 16:33
