I want to communicate various sensor data in a network of sensors.
I found MQTT and MQTT-SN as suitable protocols for that. The latter being better suited for sensor networks with support for sleeping devices, predefined communication, alternatives to TCP, etc. (https://stackoverflow.com/a/29083422)
However, both are payload agnostic. The message sent can be of arbitrary format and content. Is there a common format specifically for sensor data with small footprint?
I'd like to communicate a measurement value of a specified unit and dimensionality. Maybe with a specified tolerance/expected error. I could come up with a custom format and just shove it into the payload, but I do not want to reinvent the wheel and rather use existing formats if any exist. That would also ensure compatibility to other networks that use this format.
I found
  • an experimental proposal for an extension to XMPP which supports things like Unit or Timestamp. However, the overhead of the format being XML based makes it undesirable for my application.
    <message from='device@example.org'
             to='client@example.org/amr'>
       <fields xmlns='urn:xmpp:iot:sensordata' seqnr='1' done='true'>
          <node nodeId='Device01'>
             <timestamp value='2013-03-07T16:24:30'>
                <numeric name='Temperature' momentary='true' automaticReadout='true' value='23.4' unit='°C'/>
             </timestamp>
          </node>
       </fields>
    </message>
  • Home Assistant, which specifies a format that also has unit_of_measurement and value_template. But this is more about extracting data from arbitrary MQTT messages into a format of the platform instead of specifying a format for the MQTT message itself. In fact, people write extensions to use JSON in the MQTT message
Is there simply no such thing as a standard (or at least common) lightweight message format for sensor data?
Media Types for Sensor Markup Language (SENML) may be interesting for you.
Chapter 6.1.1. gives you an example:
{"e":[{ "n": "urn:dev:ow:10e2073a01080063", "v":23.5 }]}
    \$\begingroup\$ Looks like this is the most recent version. I was scared away at first when seeing JSON format, but there's also EXI which looks rather compact and suitable for embedded. It looks like there are only a few libraries out there for this. \$\endgroup\$
    – cross
    Nov 21, 2016 at 8:20
