I'm trying to write a Verilog code using a module in a .lib file, and compile the code using Synopsys design compiler. I compiled a memory module using my memory compiler, and it produced a .lib file. I think it contains a compiled memory module, but I cannot find how to use it in my Verilog code.
Using an analogy with C/C++, I think the .lib file is supposed to have something like a header file, so that I can include the header and use the module in my Verilog code. But it seems like that the .lib file don't have such header. Could anyone explain how to write a Verilog code using library modules?
  • \$\begingroup\$ I'd expect a memory compiler to produce .lib and .v as well as other files. Perhaps check if you skipped some optional step when you compiled the memory. \$\endgroup\$ – HKOB May 18 '19 at 13:18
  • \$\begingroup\$ How was the .lib of the module that you intend to use in your module generated? Was it written in VHDL/ Verilog? \$\endgroup\$ – rs747 May 18 '19 at 15:56
-1
The .lib file is a timing model library file described in a Synopsys propietary language interpreted by Synopsys STA tool PrimeTime. You won't be able to use it to synthesize a design, you must use a .db file, which is a Synopsys proprietary binary format to describe library cells like your memory.
Check out the options of your memory generator software to write out a library file (not timing library file) in .db format.
  • \$\begingroup\$ No, .lib and .db file have the same information. A .db file is a .lib file in a compiled binary format so it is usually faster. \$\endgroup\$ – HKOB May 18 '19 at 13:22
Not the answer you're looking for?Browse other questions tagged or ask your own question.
