I would like to use this PMIC but the problem is the default values for the DC/DC and LDO converters are different than what I want to use. Unfortunately the custom OTP setting to get the values we want is too expansive. I was thinking to covert the values with a step down converter like this. Are there any problems with doing dual conversion, one happening in the PMIC and then again externally.
Why are you so stuck on using a PMIC that is not a good fit for your application?
There are a plethora of various types of PMIC parts available from multiple vendors. TI has parts with multiple DC-DC converters on board that can support 2, 3, 4 or more voltage outputs that are programable via precision feedback resistors.
Whilst it may seem convenient to use a part with lots of DC-DC converters in one package I find it better from a board layout standpoint to use PMICs with two channels and then use multiple chips if additional voltage rails are needed. It is just too hard to get an optimum layout trying to cram all the inductors, resistors and capacitors around a PMIC with more than two channels.
  • \$\begingroup\$ I'm already using all of the converters but can't afford to do custom D.C. D.C. For one of the outputs, it's not worth it cost wise. Our board is high density and 25mm by 25mm, we have enough space to squeeze in the double conversion just for prototyping, but do you know if doing a double conversion is ok and what I would have to watch out for? \$\endgroup\$ – jack sexton Nov 18 '16 at 2:17
    \$\begingroup\$ Double conversion is often done using an LDO linear regulator as the second stage. The LDO will work with minimal voltage differential between input and output which is what you want to avoid heavy power loss in the secondary regulator. The LDO would be the minimal footprint way to lower a DC voltage rail down. A regular type linear regulator typically requires at least 3V across the part to function properly. \$\endgroup\$ – Michael Karas Nov 18 '16 at 2:23
    \$\begingroup\$ Read the LDO data sheet carefully. Some LDOs require careful management and design of the output capacitiance versus load to ensure stable operation. \$\endgroup\$ – Michael Karas Nov 18 '16 at 2:24
