7
(disclaimer: bit of an electronics newbie here)
I have a bunch of little magnet ball-bearings that I was playing around with the other day. I formed them into a strand, then fixed both ends leaving a small gap in the middle of the "string" allowing it to vibrate when plucked:
horizontal strand of magnetic balls
My ultimate goal is to be able to pluck this strand like a string and be able to convert the subtle (I would presume) changes in the magnetic field as the string oscillates into an analogous oscillation in voltage/current which I can supply to an arduino where weird sounds shall be produced.
This question about making a magnetic field sensor was helpful and pointed me to the Allegro A1301 IC and the Hall effect, which might be what I'm looking for but I suspect won't work for me here.
I also wondered whether I could use inductance here in a way similar but sort of opposite to the inductive phone tap here.
    \$\begingroup\$ Very cool idea. \$\endgroup\$
    – Ben Voigt
    Commented Feb 22, 2012 at 19:06
Yes, you will be able to use a coil to produce a varying voltage which you can then amplify and input to a microcontroller. While it would be possible to provide a coil that produced signals at a level suitable for direct input to a uC ADC, in most cases you will end up with very small signals which need to be amplified.
Use of a linear hall cell is liable to be easier overall.
The A1301 is a good choice. Not in stock at Digikey.
Digikey do have this Honeywell SS39ET Hall sensor that looks good.
$1.44/1 in stock
  • \$\begingroup\$ Thanks, Russell! I guess I'll have to just play around with it and see if one of these ICs will do the trick. \$\endgroup\$
    – jberryman
    Commented Feb 22, 2012 at 14:46
