I have a sealed lead acid battery with the spec as below:
6V 4.5Ah/20HR
Constant voltage charge
Cycle use : 7.25V-7.45V
Initial current : less than 1.8A
Standby use: 6.8V - 8.9V
What do these data mean?
Thanks for your help.
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI have a sealed lead acid battery with the spec as below:
6V 4.5Ah/20HR
"Standby use: 6.8V - 8.9V "
It means you made a typo error.
Standby use: 6.8V - 6.9V or 6.85/3=2.28V/cell at std temp=20'C
Cycle Use= Charge-discharge voltage per cell is the std way to specify multi-cell batteries.
Normally battery chargers for SLA's must be temperature compensated to achieve rated life of 500 charge cycles. There is a float voltage range and a charge voltage range which can be discharged in this range as well so it is called CYCLE USE.
Much more can be learned by getting OEM specs not reading stuff on Ebay or Amazon
http://sa.tipa.eu/datasheet/04250135-datasheet-en.pdf
