I am using a SPARTAN 3E and have used the DCM core to generate a 50 Mhz to 25 Mhz clock to drive the VGA PORT. The reset logic I'm using is shown here.
DigitalClockManager instance_name (
.CLKIN_IN(CLK_50MHZ),
.RST_IN(rst_in),
.CLKFX_OUT(clk), //25 Mhz
.CLKIN_IBUFG_OUT(CLKIN_IBUFG_OUT),
.CLK0_OUT(),
.LOCKED_OUT(LOCKED),
.STATUS_OUT(STATUS)
BUFG buffer (.I(CLKIN_IBUFG_OUT), .O(CLKIN));
RESET LOGIC :
reg LOCKED_R;
reg [3 : 0] SR;
always @ (posedge CLKIN)
begin
if(RESET)
begin
SR [3 : 0] <= 4'b111;
LOCKED_R <=0;
end
else
begin
LOCKED_R <= LOCKED;
if(LOCKED < LOCKED_R | STATUS [1] ) // H to L on LOCKED | CLKIN UNSTABLE
SR <= {1'b1 , SR[3 : 1]};
else
SR <= {1'b0 , SR[3 : 1]};
end
end
assign rst_in = ( (SR[2] | SR[1] | SR[0]) || RESET);
Now, I am not sure about how to implement reset for all the other registers in the design.
always @ (posedge clk)
begin
if (LOCKED && !STATUS[1])
begin
//GOOD TO GO
end
else
begin
//RESET
end
end
If the RESET signal pulse lasts for a period shorter than what it takes to assert the locked signal, (which probably will be the case because of the OR gate at the rst_in), the registers will never be reset.
Does the always @ (posedge clk) trigger even when (LOCKED && !STATUS1) isn't high?If so, why doesn't the else part trigger and set registers to default values?
