This is how S/PDIF to TTL converter usually looks like. I simulated poor quality smoothed out signal with a sine wave.
Can comeone explain how it really works? Inverter with feedback resistor confuses me a bit. My intuitive approach would be to use a voltage divider to bias inverter's input to it's threshold point. On the schematic above it becomes properly biased automatically.
In the question's circuit
  • A2 is used as an analog (negative) gain stage. Likely, the circuit is designed with A2 an un-buffered inverter, which can be linearized by negative feedback.
  • A1 provides further gain, making the output digital. It also happens to restore the original polarity (within some phase shift), but that's immaterial given the bi-phase mark data modulation system of S/PDIF.
  • R3 makes the impedance on the input close to 75 Ω.
  • C1 allows the A2 stage to operate with a DC offset, and attenuates low frequency. Together with R1 (and A2), it forms a high-pass filter. That greatly improves the circuit's immunity to 50/60 Hz AC power ground loop currents. Loss of low frequency is fine given the bi-phase mark data modulation system of S/PDIF.
  • R1 gives negative feedback to A2, stabilizing it's DC bias, and makes A2 operate in a linear region for small signal.
  • R2 shifts A2's operating point, and likely stabilizes the output of A1 to high in the absence of signal (that would be the case if A1/A2 came from the same 74HCU04 circuit). Perhaps it lowers A1's gain, or makes it more reproducible. But I think removing R2 would not prevent operation, at least when there is signal.
R1 provides hysteresis to the comparator so that it will not "dither" when the voltage is close to the threshold.
https://en.wikipedia.org/wiki/Comparator#Hysteresis
    \$\begingroup\$ No, R1 does not provided hysteresis, at all, for it gives negative feedback. It's role is to provides DC bias for A2. \$\endgroup\$
    – fgrieu
    Feb 27, 2022 at 15:17
