I'm trying to build a circuit that balance each cells from lipo battery by discharging them until all of the higher voltage cells are the same voltage as the cell lowest in voltage. Most of the time around 3.8V.
Arduino will be used to monitor the voltage of each cell and to control the mosfets. My electronics knowledge is near to nothing, so I would be glad if someone can help me verify if the circuit below would work.
Will be using a 1Ω 20W clay resistors to discharge each cells, with 1Ω resistance, the highest it would discharge is 4.2A (Max voltage of a lipo would be 4.2V), around 18W at 4.2V.
Mosfets I'm having in mind is FQP30N06L or CEP6030L, both a logic level mosfet, which doesn't matter at the moment until I can figure out whether the circuit would work.
