I want to trigger events on the raspberry (3) with an Arduino. Because of very contrary statements to this, i am kinda Lost. Arduino outputs 5V, that should be read by an Input of the Raspberry. Just slow Low/High Values, kinda like Buttons presses.
Different Possibilities I found:
  • Voltage Divider from 5v to 3,3v for Raspberry Pi (for example: 10k and 18k, for ~3v on the Input): That would the way that I think it is the easiest. But I stumbled over a lot of statements that say they would not recommend that, because of burned GPIOs. And the pullups of the Raspberry GPIO should be a problem. Later I found that the raspberry has software set able pull up/down resistors. It feels like lots of people don't know that they can disable them?
  • Voltage Level Breakout boards: That would be the easy way to go, but costs money and I don't need a bidirectional connection.
  • Levelshifter ICs: self explanatory.
  • Circtuit with a Transitor: Self explanatory, that would be my choice if Voltage Divider don't work.
So perhaps you can explain me what fact is against using a Voltage divider to connect these two boards. I just want to understand the issue, if there is one. :)
Cheers Michael
    \$\begingroup\$ A voltage divider is ok, if you want extra protection you can add clamp diodes to 3.3V. Alternatively, you can use a 3.3V Arduino for example with a series resistor. Will they be far away from each other? Are you using different power supplies..? \$\endgroup\$
    – Wesley Lee
    Nov 22, 2016 at 13:46
  • \$\begingroup\$ Power Supplies are the same and the the boards lay next to each other. Do you mean Zener diode with clamp diodes? ok, my fault. I searched google for "clamp diodes" and only got bad hits. "clamp diode" did the trick... Thanks for your help! :) \$\endgroup\$
    – Polle
    Nov 30, 2016 at 10:33
As you said, a resistive divider would be the easiest. Clamp diodes are cheap to add and provide extra protection.
If you are using different power supplies for each of the devices and want isolation between them, you can use a common optocoupler such as 4N25, PC817, etc..
  • \$\begingroup\$ Thanks for the useful insight, helped a lot! The Optocoupler is actually a good Idea for that situation. I will take the route with the voltage divider + diodes, thought. \$\endgroup\$
    – Polle
    Nov 30, 2016 at 10:38
  • \$\begingroup\$ @Polle -- glad that I could help, good luck! \$\endgroup\$
    – Wesley Lee
    Nov 30, 2016 at 11:22
