This question already has an answer here:
I'm trying to understand the derivation of the transfer function for the following electrical system:
Where \$k\$ is some forward gain element and \$G_{s}\$ is the transfer function of some plant. According to an instruction video, the transfer function for this whole system is $$T(s) = \frac{Y}{R} = \frac{k G_{s} }{1+kG_{s}} .$$
I am wondering how this expression for \$T(s)\$ can be derived. It probably has something to do with the control mechanism, but I am not an electrical engineer so I'm not sure how to derive this expression. I do have a background in mathematics though, so maybe you can take that into account in your answer.
marked as duplicate by Justin, Andy aka, JRE, Voltage Spike, ThreePhaseEel Nov 22 '16 at 23:50
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
  • \$\begingroup\$ This is a very similar answer to what you are looking for: electronics.stackexchange.com/a/233239/108065 \$\endgroup\$ – Big6 Nov 22 '16 at 14:53
  • \$\begingroup\$ Visual inspection: (R-Y)*K*Gs=Y. Solve for Y/R. \$\endgroup\$ – LvW Nov 22 '16 at 15:00
Just write out the control system into an equation and solve for Y/R ([Signal out] / [Signal in]
Sorry I have not figured out the math function yet.
Y = (R - Y)kGs
Y = RkGs - YkGs
Y + YkGs = RkGs
Y*(1 + kGs) = Rk*Gs
Y/R = kGs / (1 + kGs)
  • \$\begingroup\$ Thank you! How do you see that \$ Y = (R - Y) k G_{s} \$ , though? \$\endgroup\$ – Max Muller Nov 22 '16 at 15:25
  • \$\begingroup\$ R is your input and Y is your output so you can start with: \$\endgroup\$ – Steve771 Nov 22 '16 at 15:54
  • \$\begingroup\$ Y = R Then there us a node at which R is added and Y is subtracted. You need to think of Y and R as values at a given point. Now you have: Y = (R - Y) You then multiply by the gain k and the system Gs to arrive at: Y = (R-Y)*k*Gs \$\endgroup\$ – Steve771 Nov 22 '16 at 15:59
Y = Gs(R-Y)K
So, just use your algebra skills to isolate what Y is.
Transfer function is defined as Y/R.
Walking backwards from the output to determine what Y is, you see that Y is the output of a transfer function Gs. There's an amplification of K before that so you end up with $$<stuff>*K*Gs=Y $$ "stuff" is the output of the adder/subtractor which happens to be adding R and subtracting Y so you end up with $$(R-Y)*K*Gs = Y $$
Solve for Y/R and you get the transfer function.
