I have a few question about designing a heater control board . Firstly I took a power electronics lecture in the university eon ago but now I try to remember it anew. :)) Regarding my subject, I have an old dental furnace (ivoclar p80) which runs AC 230V and makes heat up to 1200 Celcius degree and it is totally 1800Watts. and I want to design my own control board for this oldy one. Actually I have searched some different boards in term of electronics component but I'm confused. Therefore may I learn which important points of should I be noted to design. For example which silicon device I should use such as power mosfet,src,IGBT so on. one that shall I use optocoupler to drive the switching device or a filter to prevent signal noise and such different questions :)) also I need to control the temp val sensitively. If you could help me it would be appreciated! Thanks in advance!
    \$\begingroup\$ You should be able to buy an off-the-shelf solution somewhere \$\endgroup\$ – JIm Dearden Nov 23 '16 at 13:32
  • \$\begingroup\$ If you really want to build your own then go with an opto coupled diac driving a triac , full wave power controller/ solid state relay . (e.g. bristolwatch.com/ele/triacs2.htm ) This will make interfacing with the temperature controls much safer. What you're looking for is a closed loop temperature control system. \$\endgroup\$ – JIm Dearden Nov 23 '16 at 14:10
  • \$\begingroup\$ Hi JIm Dearden! thank you so much for your great comment! it seems the comment is worth investigating. I will explore it some more. \$\endgroup\$ – alptugrul34 Nov 23 '16 at 17:37
Buy an off-the-shelf PID self-tuning temperature controller. Find out what the sensor used in the oven is first. You can use the controller to switch a mechanical contactor, a mercury displacement relay or an SSR. Make sure the controller matches the output device as well. Output can be a relatively long 'PWM' (a few seconds if a zero-voltage switching SSR or about 20 seconds if a mechanical contactor). If you use an SSR you will have about 8-10W to get rid of so you may need a big heatsink or a smaller heatsink and a fan.
The controllers are not particularly expensive, a few hundred dollars for a really good one, and crappy ones from China are almost free (but tend to be only type K, still probably better than something you would build on the first try).
Some have optional communications via RS485, for example. If you need to get it to talk to something, buy one with communications and you can hook it to a PC or an Arudino or a RPi etc. Some have programmable ramp and soak.
The sensor is undoubtedly a thermocouple, probably type K, N, S or R. The latter two are platinum alloy types, the first are base metal alloy types and will be much thicker wire at the sensing junction. You must maintain thermocouple wire (or proper extension leadwire), in the correct polarity, from the sensor right back to the controller terminal block. The Pt alloy sensors are very low output per degree so a better controller is indicated to maintain accuracy.
Keep the electronics cool and it will last a very long time.
If you really, really want to spend the time to develop a controller, which is not remotely a cost-effective use of time unless you intend to sell these in fair quantities, first you must figure out how to measure the sensor, including signal conditioning, cold-junction compensation and linearization, with acceptable noise level (more challenging for Platinum types) and update rate (10x per second is more than enough, less is probably acceptable. You can buy chips to do some or all of this, with varying degrees of performance and limitations.
Then you must implement a PID algorithm for control. There is plenty of information out on the web on PID- if you care about overshoot and good control it may be non-trivial.
After those two, you can proceed as if you had purchased a simple controller. Otherwise, implement timing and ramping for a more complex programmable controller.
    \$\begingroup\$ thank you so much! Spehro, indeed your comment is perfect! and it is greatly useful for me and others. I learned a lot of information thanks to you! I will search all of that you said. \$\endgroup\$ – alptugrul34 Nov 23 '16 at 17:56
