-5
The description on a web suggest that this circuit will give signals till 100 meters. I am very close to the airport so this is not acceptable. The input is only 3V so I feel the website is wrong.
Your circuit is not acceptable no matter how far you are away from an airport. Jamming is illegal in most parts of this planet. The range depends on: the battery voltage, the circuit, the antenna coupling, and the exact nature of the antenna.
That circuit probably won't oscillate, so no worries! What's the purpose of C5? Never saw that before in an emitter-coupled feedback oscillator. And 100k resistor for R2 - is that correct? Seriously, check the circuit. Or look for another source.
    \$\begingroup\$ One source of this circuit appears to be: electronicshub.org/mobile-jammer-circuit It is illegal to jam cell phone frequencies and given the sensitivity to terrorist and criminal activity, you could easily end up behind bars. \$\endgroup\$ – Richard Crowley Nov 26 '16 at 5:22
  • \$\begingroup\$ This one seems to be the electronic equivalent of a 6C homeopathic medicine (of course intent might figure into what happens to OP). \$\endgroup\$ – Spehro Pefhany Nov 26 '16 at 5:49
