I have a question concerning a power adapter. I bought a weather station from US but I live in Sweden with EU electric plug 220V.
The original power adaptor has the following spec.
Input : 120V AC 60HZ 6VA. Output : 5V DC 100mA.
Which option is the best ? Step down ? Can I use a 5V output voltage adaptor with my 220V input ?
Thanks in advance.
closed as off-topic by Olin Lathrop, Voltage Spike, Dave Tweed Nov 29 '16 at 18:03
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the use of electronic devices are off-topic as this site is intended specifically for questions on electronics design." – Dave Tweed
If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ Thanks for you fast reply.my intension was not to plug the 120V adaptor to my 220V plug, (won't feat anyway) i just thought instead of buying a step down adapter use a multipurpose adapter from my country with 220V input and 5V output \$\endgroup\$ – user131314 Nov 27 '16 at 14:03
  • \$\begingroup\$ I stopped reading at the first word since you couldn't even be bothered to capitalize the word "I" and the first letter of the first sentence. Whether you're too sloppy to care or too arrogant to bother, you get a -1 either way. Go away until you can show some respect, and show that you are taking your own problem seriously. \$\endgroup\$ – Olin Lathrop Nov 27 '16 at 14:03
  • \$\begingroup\$ Sorry sir, I never thought that a uncapitalize letter can harm so much someone, this was not my intension. \$\endgroup\$ – user131314 Nov 27 '16 at 14:15
  • \$\begingroup\$ Not capitalising the I in English is considered a sign of lack of self respect in some circles, that should bother you more than the formality that many believe the Stack Exchange site deserves. Your spell checker should point them out to you even if your input device struggles though I see you have used capitals in most of the other places correctly. Best to take care if you want the best value from the site. \$\endgroup\$ – KalleMP Nov 27 '16 at 14:45
    \$\begingroup\$ @Kalle: It's more a sign of "Eh, you're just a bunch of unimportant peons, so I can dump whatever slop on you I feel like, and you have to take it. Your aggrevation in having to read my question isn't worth my time to bother following even universal and easy rules.". Or put another way "I'm more important that all you dweebs!". I see the OP still hasn't fixed it. In fact, now some bystander did, so the OP can no longer redeem himself at all. -1 and voting to close again if I could. \$\endgroup\$ – Olin Lathrop Nov 27 '16 at 14:57
Get yourself a new adapter that works in your country and produces a regulated 5 volt output capable of supplying up to 100 mA - this is by far the cheapest option.
