I bought an XBee-PRO S1 .. I built its serial explorer to be able to configure it through the PC, I’m using X-CTU to configure and test it at first it worked well,I made test/query successfully many times I tried to write a modem configuration to it .. but each time ended with a failed message, through this the chip was still responding to the test/query, and the terminal command "+++", but trying to configure it 3 or 4 more times it stopped responding, well, I figured I was wrongly configuring it, as I didn't use the reset to reset the chip before writing the new configuration to it .. then i fixed my explorer circuit, and tried using a reset button, it worked one or two times, and a progress bar appeared, but the process failed too .. now the XBee isn't responding any more for any of what I did before .. I searched, and found many people facing the same problem ..
This problem happened with two modules in row .....
In short “I write +++ it responds OK , If started to configure say AT..anything , It stops & no respond , if I tried “+++” again .. no respond , it’s even not recognized by the X-CTU” ...
I hope I can find help about what should I do to recover this XBee, and what mistakes did I do so I can avoid them in future .........
Update #1:-
I contacted the manufacture digi(dot).com
Support: In order to change the firmware on the radio, the DTR and RTS lines are required. To resolve your issue, I would recommend either acquire one of our XBIB interface boars or you follow the steps outlined at http://www.youtube.com/watch?v=fxOqQZD-oaM once the DTR and RTS lines are connected using the proper level shifting.
As described in the product manual, the radio is a 3V device and is NOT 5V or RS232 level tolerant. You need to use a level shifter between the radio and the PC or some other Non 3V CMOS level device. Otherwise you will damage the module.
You can see a sample schematic of our XBIB interface boards buy going to http://www.digi.com/support/kbase/kbaseresultdetl?id=2118. However if you are not familiar with level shifting, I would strongly recommend acquiring one of our XBIB development boards as it will give you a known starting point to work from.
Me after the update :
Of course nothing worked from the support !
The behavior I noticed that :-
When I press the reset for a while (4 ~5 ) seconds , the CTS line in XCTU is lighted up(Green) ..... So ?
  • \$\begingroup\$ What kind of ranges are you wanting to transmit data over? \$\endgroup\$
    – sptrks
    Commented Feb 25, 2012 at 22:25
    \$\begingroup\$ @sptrks do you mean the frequency range ? .. 2.4 GHz .. as it is a free frequency for developing .. i also need it to transmit with a minimum radius 60 m \$\endgroup\$
    – mina_g
    Commented Feb 25, 2012 at 22:46
    \$\begingroup\$ @mina_g before your support ticket, were applying 5V signaling directly to the module without level shifting it to 3V signaling? If so you may have done permanent damage. \$\endgroup\$
    – vicatcu
    Commented Feb 28, 2012 at 16:41
  • \$\begingroup\$ @vicatcu No, the VCC of the max232 is on 3.3 V (accurately 3.16 v), i measured its outputs going to the XBee, they are from 0 to 3.16 V \$\endgroup\$
    – mina_g
    Commented Feb 28, 2012 at 17:38
    \$\begingroup\$ after searching more, i think that my XBee bootloader is broken .. anyone has a solution or confirmation for this ?! \$\endgroup\$
    – mina_g
    Commented Feb 29, 2012 at 21:51
I've just made an instructable for this problem. I have not proven them to work with Series 1 XBees yet, but this should be the same solution for each Series one and two. Try it and let me know the results! http://www.instructables.com/id/Restoring-your-broken-XBee/
