Say in VHDL I have an entity with as input a 8-bit vector:
libary ieee;
use ieee.std_logic_1164.all;
entity example is
port(
    clk : in std_logic;
    inputvector : in std_logic_vector(7 downto 0);
    outputvector : out std_logic_vector(2 downto 0)
end entity example;
I want to output the position of the most significant bit being one in the input vector (starting with counting from zero).
So for example if \$\text{inputvector} = [\underset{7}0,\underset{6}0,\underset{5}1,\underset{4}0,\underset{3}1,\underset{2}1,\underset{1}0,\underset{0}1]\$, the most significant bit being one is bit \$5\$. And since \$(5)_{\text{decimal}} = (101)_\text{binary}\$, the output must be \$\text{outputvector} = [1, 0,1]\$.
What do I need to write in the architecture of example to achieve this?
Thanks in advance.
Edit: How I would do this in Matlab or Python (with from numpy import ceil, log2):
ceil(log2(x)) - 1
with x the inputvalue. So \$x = (101101)_\text{binary} = (45)_\text{decimal}\$ would give
>> ceil(log2(45)) - 1
ans =
  • \$\begingroup\$ I can only sugget to a switch statement where you check the value of each bit starting from 7 downto 0 \$\endgroup\$ – Engine Nov 28 '16 at 9:29
  • \$\begingroup\$ If you have the space, a 256-entry LUT is the fastest way to do this. \$\endgroup\$ – Ignacio Vazquez-Abrams Nov 28 '16 at 9:30
  • \$\begingroup\$ I would use an 8-bit shift register shifting to the left until you get your '1' and outputting a 3-bit counter incremented each clock cycle \$\endgroup\$ – A. Kieffer Nov 28 '16 at 9:37
What you are asking for is called a 'Priority Encoder'. For an example, see this existing question:
https://stackoverflow.com/questions/14113125/short-way-to-write-vhdl-priority-encoder
Looking at that example, you would replace switch with your input, and assign your output using highest_switch.
| improve this answer | |
