I am trying to use Spartan 3E kit to generate 50 MHz clock. The kit comes along with a 50 MHz crystal which I am trying to use.
So, I wrote a simple code to output the clock from the FPGA to the SMA connector. The code is as follows:
module clock (in_clock, out_clock);
input in_clock;
output out_clock;
wire in_clock;
reg out_clock;
always @in_clock
out_clock = in_clock;
endmodule
The UCF file which mentions the pin configuration is as follows:
NET "in_clock" LOC = C9;
NET "out_clock" LOC = A10;
The output waveform of the 50 MHz clock looks like the following. The waveform is of 50 MHz but I do not get square pulses. In addition to that, the voltage level is too small (<10 mV). Can someone please tell me where the problem could be? 50 MHz clock http://www.ee.iitb.ac.in/student/~neelsmehta/2012-02-23%2011.08.20.jpg
    \$\begingroup\$ Are you certain you aren't using a 10X or 100X oscilloscope probe? \$\endgroup\$ Feb 27, 2012 at 6:29
4 Answers 4
The 50 MHz clock input should be on pin D9, not C9. You should double check this, as I could be reading the schematics wrong and assuming too many things that you left out of your question.
IF your signal amplitude were close to 3.3v then the not-so-square square-wave would be the result of how you are terminating your signal (probably no termination) and bad o-scope measurement techniques. But since your "signal" is only 10 mV, I think there are other issues.
I should also mention that I don't know Verilog, so I'm assuming that your Verilog code is good. I'm more of a VHDL person...
So, my best guess at what is going wrong is this... You have your clock input on the wrong pin. Your scope probe is on the correct signal, but there is nothing there. You're seeing a 50 MHz signal on the o-scope because of crosstalk and other noise effects and this signal is not actually being output from the FPGA.
  • \$\begingroup\$ The documentation available here clearly indicates that the 50 MHz Clock Oscillator is on C9. Please refer to the Chapter-3 Clock Sources. The image on page 21 also highlights the same. \$\endgroup\$
    – Neel Mehta
    Feb 26, 2012 at 16:26
    \$\begingroup\$ @NeelMehta Ummm... The link you provided in your question and the link you gave in the above comment point to different boards! So which one is the correct board? \$\endgroup\$
    – user3624
    Feb 26, 2012 at 16:57
  • \$\begingroup\$ I am extremely sorry that I had put in the wrong link. I had pointed to the Spartan 3 board instead of Spartan 3E board. I have corrected my mistake in the question too. I am extremely sorry for the confusion. \$\endgroup\$
    – Neel Mehta
    Feb 27, 2012 at 6:17
  • \$\begingroup\$ @NeelMehta Oh well, mistakes happen. Put the scope on the direct output of the oscillator to see what a "real 50 MHz clk" should look like. This is to make sure that the scope is set up right. Other than that, the only thing I can think of is making sure that JP9 (sheet 9/14 in the schematics) is installed correctly. \$\endgroup\$
    – user3624
    Feb 27, 2012 at 13:45
  • \$\begingroup\$ The oscillator is soldered into the FPGA and hence I cannot remove it. The jumper J9 is used to set the voltage to 3.3V or 2.5V and currently it is set to 3.3V. I am not sure but is it possible that the distortion is due to the oscilloscope probe wire/cable? \$\endgroup\$
    – Neel Mehta
    Feb 27, 2012 at 13:48
This is coming a bit late, but one thing that would explain getting only 10 mV output is if JP9 has no jumper loaded. That would mean that there's no board-level connection to power for the IO buffers that should be driving this output, and you'd nominally expect no output at all.
But its possible there's a parasitic path to those drivers' power supply from some other power input, or just signal leak-through through the un-powered circuits, allowing you to see the very small output signal.
  • \$\begingroup\$ No, the JP9 is set properly to 3.3V. I have still not yet been able to figure out the problem. So, I am thinking of writing a frequency divider code which would reduce the frequency to kHz and then try to see the waveform. I am not sure but this might help understand the source of the problem. \$\endgroup\$
    – Neel Mehta
    Mar 3, 2012 at 21:02
This doesn't answer your question, but to follow up on David's answer, you can simplify your code significantly:
input in_clock;
output out_clock;
assign out_clock = in_clock;
endmodule
  • It's not necessary to declare an input as wire or reg, because it can never be a reg.
  • out_clock is better implemented as a wire than a reg, since you're implementing it with combinatorial logic. The only case I know where combinatorial logic is commonly expressed with an always block is to generate a multiplexer.
  • There's no need to explicitly declare a port net as a wire, because that's the default.
I believe that what you wrote should also give the same behavior as this code, but it would be worth trying out the simpler form, because synthesis tools work by recognizing common patterns in your code, so if express your design in an "unusual" way, its possible to confuse the synthesis tool. In this case, it might see your always block and attempt to implement a latch or flip-flop. Which would result in incorrect logic for your design.
  • \$\begingroup\$ I ran the simplified code and checked out the Technology schematic and the schematic is still the same as the original code. I even implemented it on the FPGA and tested it out and the waveform is still distorted. So, the simplification did not help. \$\endgroup\$
    – Neel Mehta
    Feb 27, 2012 at 12:16
The input impedance needs to be 1 Mohm and not 50 ohm.
  • \$\begingroup\$ That would do it. \$\endgroup\$ Mar 13, 2012 at 22:23
