Is using a second order bandpass filter less effective than using a second order high pass filter and a second order low pass filter one after the other?
I tried a bandpass filter to filter out frequencies between 0.5Hz and 15Hz, and found that there was still quite a bit of noise.
Then I used a second order high pass filter and a second order low pass filter one after the other and found that that eliminated more noise than a bandpass filter.
Why would a bandpass be worse than a high pass and low pass one after the other?
