I was trying to design a driver of a proportional valve. My driver has ±10VDC input and ±100mA output (Load: 200 ohm, 0.5 H, Series RL) I have two supplies which are 28±4VDC and -28±4VDC. I applied this circuit and simulated. I take ±100mA when i applied ±32VDC to opamps supplies however i took ±90mA for ±28VDC and ±75mA for ±24VDC. It was fixed to 100mA when i applied bigger supplies than ±32VDC. Also there is some problem about load, the output current should be independent from load resistor but values bigger than 200 ohm, the current was influenced. I have included the circuit.
I investigated some proportional valve models and i realised that they can give almost 3A. Do you know that how that circuits can give those currents? My circuit is limited at some values for some reasons but i couldn't find it.
This is a commercial circuit example for proportional valve: http://agsotomasyon.com.tr/content/ags-pv02-2-kanal-oransal-valf-kontrol-karti
    \$\begingroup\$ Mmm what about Ohm's law? You have 200Ω load and 100Ω shunt in series. What's the maximum current which can flow when powered by 30V? \$\endgroup\$
    – carloc
    Nov 29, 2016 at 10:13
A typical proportional valve driver consist of a H-bridge that is PWM driven. The base frequency is approx 2-5kHZ. You could use a DC motor or stepper motor driver with a chopper, to control the current. Moreover a valve driver has also a dithering frequency, that is superimposed on DC signal. This is a nice feature that provides anti-sticking. The friction of the spool is high, then at low currents the spool got sticked, then at higher current it suddenly frees, making jerking movements. That's why a dithering is used for.
  • \$\begingroup\$ Thank you. Is it possible to design with opamps like i did? What is the disadvantage of my circuit, how can i improve? \$\endgroup\$
    – lineout567
    Nov 29, 2016 at 14:21
    \$\begingroup\$ @lineout567 Your current-sense resistor (R7, 100 ohm) is far too large, consuming precious output voltage. Try reducing it to about 10 ohms or less. Then amplify its voltage drop with a difference amplifier. But you'll still not have enough available voltage to get more than about +/- 100mA. Marko makes good ideas. \$\endgroup\$
    – glen_geek
    Nov 29, 2016 at 14:37
