7
I am trying to make a simple MACC to work, but it does unexpected things. The multiplication is not working. 00001 * 00001 outputs 00000
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity macc is
    Port ( clk : in  STD_LOGIC;
           rst : in  STD_LOGIC;
           en : in  STD_LOGIC;
           A : in  STD_LOGIC_VECTOR (4 downto 0);
           B : in  STD_LOGIC_VECTOR (4 downto 0);
           P : out  STD_LOGIC_VECTOR (8 downto 0));
end macc;
architecture Behavioral of macc is
    signal product : STD_LOGIC_VECTOR (8 downto 0);
    signal acc_in : STD_LOGIC_VECTOR (8 downto 0);
    signal acc_out : STD_LOGIC_VECTOR (8 downto 0);
begin
    product <= A*B;
    acc_in <= acc_out + product;
        acc: process is
        begin
        wait until rising_edge(clk);
            if (rst = '1') then
                    acc_out <= (others => '0');
            elsif (en = '1') then
                    acc_out <=  acc_in;
            end if;
        end process acc;
    P <= acc_out;
end Behavioral;
Multiplication mistake
  • \$\begingroup\$ Waveform added. \$\endgroup\$ – Arturs Vancans Feb 27 '12 at 14:08
  • \$\begingroup\$ I don't remember so much about VHDL, but product should be updated asynchronously right? In that case the problem is not acc, but the actual multiplication... \$\endgroup\$ – clabacchio Feb 27 '12 at 14:15
    \$\begingroup\$ Well, that's what this posts is about. \$\endgroup\$ – Arturs Vancans Feb 27 '12 at 14:29
  • \$\begingroup\$ Yep, sorry, I was confused by the context... \$\endgroup\$ – clabacchio Feb 27 '12 at 14:31
11
If you multiply 2 5-bit numbers (A and B are both std_logic_vector(4 downto 0)) don't you need 10 bits (not 9) to store it in (so P should be std_logic_vector(9 downto 0)? (31*31 = 961: needs 10 bits)
But also - don't use std_logic_arith/_unsigned. Use ieee.numeric_std and then use the unsigned data type.
  • \$\begingroup\$ I am not allowed to change packages. Moreover I have to meet provided conventions to meet synthaseable code. Regarding the problem, the output vector length was the problem. Thank you. \$\endgroup\$ – Arturs Vancans Feb 28 '12 at 1:09
    \$\begingroup\$ Why are you not allowed to change packages? Can you not at least get rid of std_logic_arith (assuming you are doing unsigned maths)? \$\endgroup\$ – Martin Thompson Feb 28 '12 at 10:43
    \$\begingroup\$ If you are really synthesizing, then you may want to consider a simple pipelined vendor-specific core instead. \$\endgroup\$ – Aaron D. Marasco Mar 2 '12 at 1:49
  • 4
    \$\begingroup\$ @AaronD.Marasco: or just stick a * in with a few pipeline registers afterwards and let the synth tool figure out where to put them - much more portable. \$\endgroup\$ – Martin Thompson Mar 2 '12 at 13:26
