I have a problem in LTSpice with calling "component attribute" on both versions IV and XVII. Normally you should be able to call the component attribute window by pressing Ctrl+RightClick on the component (for example a Diode). Then you can enter the values that are not within LTSpice library.
But sometimes this short-key doesn't work on my computer which is running windows 10 X86. There is also no menu for it. Does anybody face this problem and knows how can I solve this problem?
